Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-20-2005, 08:30 PM
Promart Promart is offline
Cold Air Intake Blues
So as many Californian's are aware, we aren't used to seeing this kind of rain....
So Friday I'm headed home exit the Freeway and see a large puddle at the bottom of the offramp....I'm screwed....
I role through and engine dies....I'm stuck.... end up getting pushed out and towed home...well Hydrolock?
B18C1 Motor.....
So far pulled my plugs cleaned them, pushed the water out of the cylinders by clicking the ignition...drained the water out of the throttlebody and removed the CAI.
Should I try to start the car? I'm scared to do anything further at this point..... if the cylinders moved to push out the water I should be fine, no?
Any input from techies would be great.....
MF
Old 02-20-2005, 09:13 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Cold Air Intake Blues
Change your oil and then see if the car will start, but only after you know for sure that you have all the water out of the engine. I am guessing that it won't run, most of the time you bend a rod, break ring lands etc. Water does not compress near as well as air. But try it and see, you have nothing to loose really.
Old 02-21-2005, 08:04 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
I agree completely
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-21-2005, 08:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you saw the puddle and knew it was deep, you should have rolled through it with the engine off.
Team Lonely Drivers
Old 02-21-2005, 09:45 PM
i should've just stopped and called a tow truck on the offramp...but I didn't think the gutter water was that deep, I tried to coast through it, however needed my steering so off wasn't really an option.....
so I'm about to compression test to see if I'm feeling any better about attempting the start up.....
I'll keep you posted...
MF
1993 Civic LX 4dr
94 JDM B18C1 w/mugen chip
Denso Iridium Plugs
MSD 8.5mm Wires
AEM Cold Air Intake
Old 02-21-2005, 11:51 PM
shut the motor off then turn the key back to the on position, it unlocks the sterring
Team Lonely Drivers
Old 02-21-2005, 11:55 PM
so sadness sets in....2k after my swap and i'm fully hydrolocked....
cannot get the crank to turn by hand, I'm puzzled how would the pistons throw push water out of the top if my crank won't turn? maybe I'm just too weak to turn it with a rachet?
so my plans from here, starting tomorrow i pull off the head and take a peak inside......
so i learned an expensive lesson
MF
1993 Civic LX 4dr
Denso Iridium Plugs
MSD 8.5mm Wires
AEM Cold Air Intake
Old 02-22-2005, 08:30 PM
sivic02's Avatar
sivic02 sivic02 is offline
eek! sorry to hear about that man, we dont get bad rain in south carolina either so i know what you mean, if we get an occasional hard downpour im hesitant to drive on these crappy roads, good luck with the motor
Here's to being single, seeing double, and sleeping triple
Old 02-23-2005, 11:31 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
MF
after you pushed the water out i'm assuming you didn't spray WD-40 or something of that sort into your cylanders to lubricate it? sooo i'm guessing the reason it won't crank now is because its rusted up.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 02-23-2005, 11:56 AM
notyouraveragegirl's Avatar
notyouraveragegirl notyouraveragegirl is offline
Send a message via AIM to notyouraveragegirl
MF
I'll send a prayer out to your dearly departed - almost had the same issue but got lucky and managed to fix it: so I hope this helps, if you didn't already know:
when you get around to it again, invest the extra 50 bucks in an intake bypass valve.. ...it's made specifically to keep your car from hydrolocking by keeping the water out because you never know
good luck
Old 02-23-2005, 01:06 PM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
yeah make sure u change ur oil and it should start.
