Old 02-20-2005, 08:13 PM
TunerAdept TunerAdept is offline
tranny shifting prob
ok, th700r4 auto tranny. when i leave it in first gear (have a b&m ratchet shifter) it will shift into second at about 3500 rpms. its still in first on the stick but it shifts into second. it did this before i installed the shifter with the stock one. would a manual-automatic shift kit fix this? if not what will...?
Old 02-22-2005, 09:47 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
I didn't think 700R4's did this but I know 400 Turbos do, it's called govern shifting. When the RPM's reach a certain point, the line pressure in the trans builds up and it shifts on it's own. I know on the 400, it will only govern shift from 1-2. BTW, this is kinda hard on the trans so I wouldn't make a habit of it ( I used to do it every time I drove the S10, but I knew I was going to rebuild it so...what the hell!!)
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 02-27-2005, 08:21 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Sounds Shifty
Originally Posted by TunerAdept
........when i leave it in first gear.......it will shift into second at about 3500 rpm..........?
(We are assuming it's floored when this happens)
That's so you don't over-rev. However 3500 is too early. Mine is set at 5500. Yes you can have mods done so it shifts at a higher RPM.
REFUSE
. . TO . . LOSE
