Old 02-20-2005, 08:09 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
'nother update: and pics
just wanted to show u guys what i got done, i had to make some custome brackets for my head unit because it was sticking out and making the trim plate bow a bit... here's an after shot
i recently took my headers off, had that 1200 degree paint removed, and got them and my y-pipe ceramic coated. unfortunately i forgot to take some pics before i put them back in... so here are some pics of the stuff on the car, sorry bout the under the car shots, i can't really pull back when i'm underneath lol
here is a pullback of the engine, just so you guys can get an idea of how much is put together... i haven't got to do much in the bay recently...
here is my crossmemeber, torque arm, panhard rod and sway bar from spohn. i remembered i never showed u guys my suspension. if any of u guys want to see the other suspension stuff i've done i can take more pics... just ask
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 02-20-2005, 08:18 PM
tardster tardster is offline
Your making me jealous................................LOL
Old 02-20-2005, 08:38 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: 'nother update: and pics
That car is going to be awsome when you are done. Good job so far
White 07 STI, Bone stock for now
Old 02-20-2005, 09:00 PM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
i've been jealous ever since i seen his paint job... lol
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 02-20-2005, 09:34 PM
I-ROC KID I-ROC KID is offline
good call the paints unreal u better take good care of that car
355 small block 4 bolt, 700R4 tranny/w shift kit, elbrock 650 carb, elbrock intake, mild cam, 3.73 posi rear end, 3" cowl hood, 3" exhust, b&m mega shifter, k&n air filter, ac delete
Old 02-20-2005, 10:20 PM
panchoman's Avatar
panchoman panchoman is offline
Send a message via AIM to panchoman Send a message via MSN to panchoman Send a message via Yahoo to panchoman
i friggin love your car man
"Hasta la victoria siempre!"-Ernesto "Che" Guevara
Old 02-20-2005, 10:53 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
some step by step details on the torque arm removal and install would be awesome.
Old 02-20-2005, 10:55 PM
ViperJ's Avatar
Re: Re: 'nother update: and pics
Are you going to get it dynoed when you are done, or do you know how much hp and torque you have. I am just curious...
Old 02-21-2005, 01:02 AM
LuminaRacer05 LuminaRacer05 is offline
lookin nice man, real nice
1991 z28 350 tpi chameleon paint
Old 02-21-2005, 10:21 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Thats going to be one sweet ride when your done. I hope your worthy but if not I think you should give it to me.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-21-2005, 10:59 AM
the torque arm was very straight-forward. i got the adjustible torque arm, and crossmember (with driveshaft loop) all from spohn racing.
i had the car on four jackstands, dropped the driveshaft, supported the back of the third member (so it would rotate backwards), supported the transmission, removed the crossmember, unbolted the torque arm, removed the old bracket that attached the torque arm to the tranny, bolted up the new crossmember, then bolted up the torque arm (which first attaches to be thirdmember w/ 2 bolts, then it bolts to the crossmember instead of the bracket on the tranny)
that was an abreviated version, basic steps. i still have to learn how to set the pinion angle which i haven't done yet... but the spohn torque arm came with an angle finder which makes it easier
Old 02-21-2005, 11:13 AM
i couldn't do that john, you are on the darkside
Old 02-21-2005, 11:18 AM
Re: Re: Re: 'nother update: and pics
i plan to take it to a place where i can use a chasis dyno, stock lt1's push about 275 to the wheels, so i want to see how much better than that i can do...
