Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-20-2005, 07:50 PM
Evolcivic Evolcivic is offline
Headlight Blub replacement 96 Civic?
I got the plug and boot off, just wondering how I get the bulb out. I can barely see what appears to be a retention wire, but I don't want to break anything. Can someone walk me through this? Much appreciated...
Old 02-20-2005, 09:47 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Headlight Blub replacement 96 Civic?
I think you just remove that metal clip and then the bulb will pull straight out. Someone correct me if I am wrong though.
Old 02-20-2005, 10:09 PM
96CivicEX06's Avatar
96CivicEX06 96CivicEX06 is offline
Send a message via MSN to 96CivicEX06
There's a screw with a philips head that keeps the clip retaining the bulb, once you unscrew that, you just have to get the clip out, it shouldn't break unless you really put force on it. Once you get the clip out, pull the bulb out, and if you're going to use the bulb again don't touch the bulb with your fingers since oil will make it overheat and blow. If you do touch it or something else touches it, clean it with rubbing alcohol.
Silly ricer, wings are for planes
Old 02-20-2005, 11:12 PM
Thanks Guys, Got the passenger one replaced. Now I just have to figure out how to get my big paws in to change the drivers side. The wire clip just released and rotated enough to replace the bulb. Thanks again.
Old 02-22-2005, 08:33 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
the fluid right by that head light pops up, it has a red cap in my engine, jsut pull it straight up, ull see the track there
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 02-25-2005, 11:06 AM
sivic123 sivic123 is offline
So simple
That retainer does not need to be unscrewd!just push down on the retainer and it should release the bulb ok done it many times also own a 96 civic,peace!
