Old 02-20-2005, 07:46 PM
JM3401 JM3401 is offline
2000 Grand Am - Direction Signal Problem
I have a 2000 Grand Am. After making a turn, there continues to be a very fast clicking nois from the direction signal. The signal indicators on the dash board are not blinking, nor are the signals on the outside of the car. However the fast clicking sound continues intermitently long after the blinker has switched off.
Old 02-20-2005, 11:45 PM
meti meti is offline
Send a message via ICQ to meti Send a message via AIM to meti Send a message via MSN to meti Send a message via Yahoo to meti
Re: 2000 Grand Am - Direction Signal Problem
haha yes its a recall from last year but they dont pay for it anymore
Its more likely your hazard switch located just above the stereo behind the hazard switch/button!
Call a dealer and ask them how much those run.
by the way: i have the same problem and if you want you can wait untill i get my new hazard switch and try it out! it will be 1 week max untill i can tell you results
turn ur music on laud and u'll be fine for 1 week lol
Old 03-03-2005, 08:44 PM
mrgazz mrgazz is offline
Angry
I have just developed the same problem! I tried replacing the turn signal relay attached to the hazard button, but this did not correct the problem. Have you had any luck correcting this problem?
Old 03-03-2005, 09:29 PM
haha its coming in this week so i'll let you know. I called the pontiac service and they said there was teh recall but now its expired and but for my situation the switch should fix the problem but he also explained something else which i dont remember but it had something to do with the relay.
Well mine is all fine but just makes a random ticing so thats the 4 way hazard switch locataded right behind the hazard light button.
i suggest u take it to some pros to check it out if u cant fix it....
I"ll post back again and let u guys know if it fixed it my problem
Old 03-03-2005, 09:37 PM
check out this other thread. This is the exact problem and seems to point to the blinker switch (called multifunction switch) (I think the hazard recall is a seperate problem and it seems folks are confusing the two)
Thanks for your quick reply though!
http://www.automotiveforums.com/vbul...ghlight=signal
Old 03-03-2005, 10:47 PM
as you can see its the same problem as the other thread. I dont have anything else to add but suggest to change the hazard switch
once again: mine is coming in soon so i can post back here very soon telling if it fixed the problem or not!
Old 03-05-2005, 03:13 PM
I replaced the hazard switch yesterday and it seems to fix the problem.
I hope this helps you and wish you the best! ;-)
Old 03-05-2005, 04:19 PM
I took mine off and cleaned it as suggested in the other post. This corrected the problem for me. It was easy to see what was shorting out when I disassembled the multi-switch. Thanks.
