Old 02-20-2005, 07:15 PM
whiteypa whiteypa is offline
my gt 3000 only has 3rd gear (auto)
I bought a 91 gt that needed a water pump, it is a 3.0 4 cam non turbo. when i drove the car it had all the gears when i put the pump on and the new timing belt i had the one cam off one tooth off.when i drove it then it only had 3rd gear..i fixed the problem it still had only 3rd..what should i do next?..can someone help me? Mike
Old 02-20-2005, 09:55 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: my gt 3000 only has 3rd gear (auto)
hmmmmm.....
could be the ECU....
not sure - what does it exactly do?
try disconnecting the battery for like 10 mins. then hook it back up - see if the ECU will reset itself...
worth a shot -
need more info on what the car is doin - thats prob. why nobody else has hit this post yet....
u said u fixed the timing right?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 02-20-2005, 11:31 PM
StealthModifier StealthModifier is offline
the timing on the engine should have nothin to do with what gear its in.. hmmm ... put it in L or 2 an see what it does
Old 02-21-2005, 11:54 AM
Hotshot8792 Hotshot8792 is offline
if your stuck in 3rd gear in an auto, it means you are in failsafe mode. Your auto tranny is throwing codes because something could be wrong with your transmission. I would get that checked out right away.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 02-21-2005, 12:13 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
If your timming was slightly off and you turnned her over then I would be seriously worried about the internals. Timming is serious man.
as far as the tranny I think it might of just gone bad. get it checked soon.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 02-21-2005, 07:54 PM
Italian Lunaticz Italian Lunaticz is offline
Send a message via AIM to Italian Lunaticz
Just like hotshot said your in failsafe mode says it in the manual. Your car stays in 3rd gear which is suppose to be safe so you can drive to the dealership. My car had the same problem and it was the computer chip which tells the car what gear to go in was bad. Ended up costing me $1,000 to fix which i could of got fixed for alot cheaper.
93 Base 3000GT
Injen Intake
Power 1 exhaust tips
Polk audio speakers
Old 02-22-2005, 11:36 AM
$1,000 that is rough - good luck man... sorry to hear that about your car!
Old 02-22-2005, 10:16 PM
yea, mine went into failsafe mode after installing my shift kit. Pulled that sucker back out, and found out that i forgot to reinstall a shift control clip but i reinstalled it and the valve body and it was as good as new.
