fuseboxNwires?
I took a look in my fuse box there is this one wire that isnt plugged in, should it be? the other one i think is pluged into the 4X4
Also these other wires i found when cleaning my car what where they to any idea? looks like it was mounted. Just go here and check it out: http://www.geocities.com/ryanb4614/myblazer.html Also my passenger wing window is leaking everytime i go to the car wash, think i need new strips? (yes the window was close all the way) |
Re: fuseboxNwires?
looks like someone hacked into it in the past.
1995 Factory Blazer Service Manual for sale, PM if interested. |
That's not stock, that's some crap wiriing job that the previous owner used for something... Trace it back... If you find out what it's for, tap it in to a better place for power...
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: fuseboxNwires?
ok for the fuse box should that be plugged into the 4x4 ? should i unplug it?
Re: Re: fuseboxNwires?
Re: fuseboxNwires?
Was you're blazer owned by any type of law enforcement agency?
I got mine from the Florida Wildlife Commission. It has the exact same pattern holes on both sides of the center console. It also has a wire piggybacked (just like yours) that goes to a big ass reading light on the headliner. |
Re: fuseboxNwires?
Im not sure of its history... should i remove the plug that is in now? what are they for? maybe used for plowing ? have no clue
Re: fuseboxNwires?
you just have to trace the wires and see what they are for. If it isn't connected to anything or something you don't want just unhook it. If it is something you want to keep, you should think about wiring it better.
Re: fuseboxNwires?
There is no extras in my car, this wouldnt be a reason why my stero (orginal) wont play cds? come up ERR.... the one pluged into the 4x4 fuse, what could that have been used for? the on unpluged is probly to the wires that are cut by my center console, do u think one of those wires are power?(running by my center console.. then woul di be able to use them for my monitors i ordered for my headrest?
Re: fuseboxNwires?
Ryan, at this point you know that's not a stock wire, it was some sort of an add on. Why don't you trace it?
Doing something like that for power is dangerous in the long run.
Re: fuseboxNwires?
Trace the wire or my vehicles history? what could it be that is plugged into the 4x4?
Re: fuseboxNwires?
THE WIRE! Ryan, it could be a million different things, it may even be a dead wire. All they did was use that fuse for power (again not a good idea) Simply trace the wire.
Re: fuseboxNwires?
Just because it is plugged in the 4wd fuse doesn't mean it has anything to do with the 4wd. They probably used that one because it rarely has a load on it.
Re: fuseboxNwires?
okay thanks blazee thats what i was wondering... Not saying i will use this but is this how u tapp in the fusebox for power? so when i get my monitors i do something similar like that?
Re: fuseboxNwires?
All I did was clarify what rlith said.
There are a lot better ways of connecting power. The piggyback method usually doesn't get a real good connection: This causes heat in the fuse box and could damage it. This could also keep the monitors from getting the power they need to operate properly, which would damage them too. |
