Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 02-20-2005, 06:49 PM
t-ribbit t-ribbit is offline
Angry ecu code 4
i have a b16 in my crx... I cannot rev passed 3.... it is like my rev limiter is set at that point...i used a friends ecu and the same thing happened.. my pr3 ecu is blinking 4 times... i think it is the code for the crank angle sensor.... does anyone know what i can do to fix this problem...i also installed a msd system can that be the problem?? how hard is it to replace the crank angle sensor??
Old 05-30-2005, 12:21 PM
hondababy4g hondababy4g is offline
Thumbs up Re: ecu code 4
if you just put the msd in and it wasnt doing this b4 check your wirring. i dont know which msd you have but most likely you had to tap into your coil make sure all the wirres are ok good luck!
