Lanzar Amps
alrght i need to know what kinda reputation they have cuz i just found one with the specs i need...http://www.ikesound.com/product-product_id/2722
here are the specs 500 Watts x 2 RMS Power into 4 Ohms 1000 Watts x 2 Max Power into 4 Ohms 2000 Watts x 1 Max Power Bridged 750 Watts RMS Power into 2 Ohms PWM (Pulse-Width-Modulated) System Electronic Crossover Network Bass Boost Circuit Bridgeable at 4 Ohms 2 Ohm Stable Tri-Mode Capable Double Side Epoxy PCB Circuit Board Nickel Plated RCA Inputs Line Outs for Left and Right Channel Low Pass Filter Controls High Pass Filter Controls Subwoofer Remote Level Control Power and Protection LED Indicators Soft Turn On/Off Variable High Pass Filter: 50Hz~750Hz, 24dB/Octave Variable Low Pass Filter: 50Hz~120Hz, 24dB/Octave Variable Bass Boost: 0 - 18dB THD: 0.04% S/N Ratio: 100dB Channel Separation: >60dB Frequency Response: 10Hz - 35kHz (+/-1dB) Dimensions: 10.08''W x 2.12''D x 23.22''L Fuse Rating: 40A x 4 |
Re: Lanzar Amps
Hey Man...
Lanzars old stuff was THE BOMB!!! However, Lanzar is now owned by Pyramid Audio and they suck. They may be loud, but it will sound like garbage and will burn out really quickly. This is comming from experiences that my friends have had after they went against what I said. BUT...The Lanzar Opti has had some pretty decent reviews. I personally would not spend the money on Lanzar, I would rather get something that sounded good and would last a long time. As well, when you get something that is great quality...90% of the time the amps are under-rated and you get more power anyway. Soooo... I would say don't buy and and maybe spend a little more money on something that is going to sound way better, last longer and still impress.
"You can have everything in life you want if you will just help enough other people get what they want."
Re: Lanzar Amps
Yeah, the original Lanzars were awsome. I had one that I loved but these newer ones, I doubt they can actually do what they say. Also, I noticed that it calls for 4, 40amp fuses. Is this thing suppose to be a 4 channel? If so, you don't want it for subs.
Directed Audio's 750d is 10x's the amp than what you are looking at for less the money.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
Re: Re: Lanzar Amps
As well, you can use a 4 channel for subs, if it is bridgeable. Even if it can only go down to 2 channels, you can run one sub per channel and it will be fine.
Re: Re: Re: Lanzar Amps
Also, unless you have one powerhouse of a 4 channel amp and you are running something like 3 or more pairs of subs, you don't want to use a 4 channel amp. Reason is they are usually very unstable at low Ohm ratings. You never see an SPL car running 4 channels (even if bridged to 2) on a pair of subs.
Re: Lanzar Amps
Or it can be a horribly overrated amp, like most Sony Amplifiers. The difference between four 20A fuses and two 40A fuses is nothing as far as I know, I am not sure understanding as to why it would be different.
