Go Back   Automotive Forums Car Chat > Peugeot > 306
Old 02-20-2005, 02:44 PM
gazz100 gazz100 is offline
Send a message via MSN to gazz100
306 heater not working
hi all
i have just got my hands on a 1.4 l reg 306 and have got some problems with the heater not working. the engine temp was all over the place so i have changed the stat at that seems ok now. i have tryed to bleed the engine and heater matrix but still no joy. i can get some heat out of the dash vents but none from the feet or the windscreen vents any advice would be great
thanks
Old 02-20-2005, 10:53 PM
Mr Vegas Mr Vegas is offline
Hi,firstly can you get good airflow at the windscreen and foot well?or is the problem only with a lack of hot air?
When you bled the system,the heater hoses were warm right?if the heat is the only problem and the airflow is good i'd say the heater matrix is faulty.
These are quite common on old peugeot 405&3o6's.
Old 02-21-2005, 03:38 PM
Re: 306 heater not working
yes i get good air flow at all vents but warm air only at the dash vents heater hoses get warm when you bleed them but not hot do you think that a got flush out could do the job ? or would it be a new matrix
Old 02-21-2005, 03:53 PM
Skyline316 Skyline316 is offline
Banned
how about adding coolant...that will make ur heater not work and the tempature in ur car go nuts...top off ur coolant
Old 11-19-2005, 10:06 AM
DJCult DJCult is offline
Your symtoms sound exactly the same as i had on my 406.
I changed the stat, but that only improved it a small amount, so i flushed the heater matrix.
Find two pipes that go through the bulkhead to the heater matrix, undo the two pipes and put a garden hose in one to try and flush it through. i also put two mole grips onto the two flexible pipe to prevent losing to much coolant. This worked really well on my 406, heater is good as new now!
