Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 02-20-2005, 02:22 PM
88caddy 88caddy is offline
Send a message via AIM to 88caddy
Unhappy Help with map sensor and cooling system on 88 coupe deville
I have a 88 Coupe deville . The service soon light is on and i checked the computer and it was code 22, 32 , 52 . I checked the book and I found out that the map sensor is open and i found a leak in the bottom hose but dont know how it get it off HELP
Old 02-23-2005, 11:27 PM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
88 Coupe Deville? I have a 90 Coupe with the 4.5 so I assume you have the 4.1? The bottom hose goes from your radiator to your water pump. It shouldn't be that difficult to change a side from maybe reaching the bolt on the clamps. The MAP sensor however is very easy to change and I'm sure you know where that's located right?
*91 TSI AWD*
Old 02-27-2005, 05:26 PM
Edward Casper Edward Casper is offline
Re: Help with map sensor and cooling system on 88 coupe deville
Hi,
Open your hood. The map sensor is a plastic module, approximately 4 inches by 2 inches by 1/2. It is located on a metal bar in the middle of the fire wall, secured by two 3 inch long screws. It has a 3-prong electrical connector underneath (red) and a vaccuum hose underneath, coming from the middle of the left throttle body. It is black, and the GE number on top is 466. This comes from my 1988 Sedan Deville, 4.5 liter engine. The part costs about $80.00. Obviously, you should first replace the hose, and then replace the MAP sensor if the problem persists. I hope this helps.
Sincerley,
Ed Casper
