Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-20-2005, 12:46 PM
DropdHatch's Avatar
DropdHatch DropdHatch is offline
Send a message via AIM to DropdHatch
b16 Pistons and rods in b18 block
My friend has a b16 block laying in his basement. I was wondering if taking out the pistons and rods and putting them in my b18 LS if it would be a good set up to do an LS/Vtec.
Live life by the gear... My cars slow so I've been in 1st for a while.
Old 02-20-2005, 02:08 PM
boosted331 boosted331 is offline
Re: b16 Pistons and rods in b18 block
Stock B16 Rods: 5.290"
Stock B18B Rods: 5.394"
Rods don't work. Pistons will swap over and will net higher compression.
Old 02-21-2005, 12:32 AM
DropdHatch's Avatar
I need an opinion on LS/Vtec. All my friends say no matter what Ls/vtec will never work good. You will always be switchin blocks or blowing rods and what not. Even if its built he says it will never last longer then 2 months. Is this tru? I mean lots of people got Ls/Vtecs out there now. Do they go through the trouble of blowing it up all the time. Or is it just Bs Ls/Vtec can work good?
Old 02-21-2005, 01:17 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
If it's built correctly, and you don't over rev the motor, it can be pretty reliable. Just remember that you'll be running the ECU for the head, and this will have a much higher rev limiter than the LS one does. But unless you're block is built to rev high, then you can't rev the motor as high as the ECU will allow. So if you over rev it, you'll break rods and/or throw a piston thru your sleeves.
Old 02-21-2005, 01:18 AM
DropdHatch's Avatar
Whats a basic shift for ls/v also like a red line.
Old 02-21-2005, 11:32 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what ever the ecu says it is.
the most important things when doing a ls vtec if your leaving the block stock, is new arp rod bolts and a vtec oil pump
Team Lonely Drivers
Old 02-21-2005, 12:35 PM
DropdHatch's Avatar
What can a stock block hold up to
Old 02-21-2005, 04:37 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Need a block girdle too. That will help make the whole bottomend more rigid. You can use one from a GSR or ITR, you will need the oil pan, girdle, main caps, windage tray, and oil pick up. Or you can get an aftermarket one from Z10
Old 02-21-2005, 05:20 PM
but doesnt that require a line bore after?
Team Lonely Drivers
Old 02-21-2005, 08:30 PM
whtteg's Avatar
Yes
Old 02-23-2005, 02:01 PM
Medabots Medabots is offline
Is there a lot of drilling when doing a LS/Vtec?
(just curious)...
Old 02-23-2005, 05:22 PM
nope, all you gotta do is drill the head once, tap it and then plug it
Team Lonely Drivers
Old 02-23-2005, 09:01 PM
Kven's Avatar
Kven Kven is offline
Re: Re: b16 Pistons and rods in b18 block
all those people who blew their ls/vtecs within two months obviously cant drive or dont know how to build a motor. one of the things you cant really do with a stock-bottom ls/vtec is rev high, why? the rod-angle puts alot of stress on the rods, revving higher then they were intended for will break/bend the rods.
Do what everyone says above and you will have no problems.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 02-24-2005, 04:24 PM
turboEKhatch turboEKhatch is offline
Re: Re: Re: b16 Pistons and rods in b18 block
I and several people I know have ZERO problems revving LS/B20 VTEC motors high. The rod/stroke issue is blown way out of proportion. The LS/B20 is 1.54:1, the GSR/ITR is 1.58:1. Not that big of a difference, and it doesn't make a huge difference anyways.
Old 02-25-2005, 07:56 AM
Kven's Avatar
yes there are people that can get a ls/b20 to rev high, but the fact that revs cause a engine to wear faster makes it more noticeable in a ls/b20; which wasnt designed to turn high rpms without work.
it doesnt matter if the numbers arent that close, fact is the rods/rod bolts will see a higher load then the gsr.
1988 Honda CRX DX
Closed Thread
