Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-20-2005, 10:42 AM
Chrisstopher Chrisstopher is offline
Send a message via AIM to Chrisstopher Send a message via Yahoo to Chrisstopher
'94 Jimmy Fuel Pump Testing
I think I have a bad fuel pump. I've already replaced the relay on the off chance that might solve my problem. No such luck.
I also know that it could be a problem with the oil pressure sending unit. How would I go about testing each and which should I test first?
Old 02-20-2005, 02:26 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: '94 Jimmy Fuel Pump Testing
Do you hear the pump prime when you turn the key to the position just before start?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-20-2005, 06:21 PM
Re: Re: '94 Jimmy Fuel Pump Testing
Nope, nothing.
I've checked for pressure at the injector line and there was none.
I'm definitely not getting fuel.
Old 02-20-2005, 06:36 PM
BlazerLT's Avatar
AF -Advisor
Fuel pump has popped.
Might as well swap in a new sending unit while you are changing the pump as well.
Old 02-21-2005, 05:48 PM
Gee, thanks there Blazer. Now, is there anyone out there who might be able to help me by answering my question?
Old 02-21-2005, 05:52 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You need to hook a pressure gauge to your oil sending unit... then see if your getting pressure on crank. If so, it works... But if your pump isn't even priming, testing the fuel sending unit is useless, because it will still prime even if the oil sending unit switch is bad.
Old 02-21-2005, 06:57 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: '94 Jimmy Fuel Pump Testing
What the hell is your problem, you said you are NOT getting the fuel pump priming when you turn the key on.
So what is your problem with me telling you to change the obvious thing that is shot which is the fuel pump.
And while you are at it, replace the sending unit at the same time seeing it is probably rotted out.
You ask for help, I tell you what the problem is, then you whine on like I did nothing fro you.
FOR SUCK FAKES, WHAT THE HELL DO YOU WANT US TO DO!!
Old 02-22-2005, 05:51 PM
Thanks Rlith. I appreciate your help.
I had it towed to a shop this morning and it turned out to be a faulty ignition switch.
Ya' think maybe Blazer might be needing a little more fiber in his diet or what?
Old 02-22-2005, 05:57 PM
Re: Re: Re: Re: '94 Jimmy Fuel Pump Testing
Holy crap, A flaming moderator!!!
I am so impressed!!!
Lighten up there Blazer or you might wind up popping a pump of your own.
HaHaHaHaHaHaHaHa!!!!!!!!!!!!!!!
Old 02-22-2005, 06:50 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: '94 Jimmy Fuel Pump Testing
I tried to help and you rudely came back like I said something that was right out in left field about your problem.
