Old 02-20-2005, 10:56 AM
rivierax71 rivierax71 is offline
Send a message via AIM to rivierax71
Question 1993 ford escort/ trans swap/ problem
Hello, I have a 1993 ford escort with an automatic transmission. Recently the transmission when leaving from a start will shift directly into 2nd instead of going into 1st and it will shift into 3rd and thats it...it won't shift in 4th gear. I was wondering if this a transmission problem or some sort of sensor problem. Also would it be possible to put a manual transmission into it..from a 1991 Ford Escort.
Thank You
Old 02-20-2005, 09:32 PM
ALMB~Nova ALMB~Nova is offline
Re: 1993 ford escort/ trans swap/ problem
these transmissions were plaged with problems. shifting is controled electronically so it could be a sensor. check for codes, if no codes, consult a local trans shop for advise
Old 02-23-2005, 02:02 PM
alright thanks...i will look into it
Old 02-23-2005, 11:32 PM
jman63 jman63 is offline
yes, converting to a manual is possible, I changed my 91 lx wagon from auto to manual. everything bolts up. your existing drive axles fit.
