Old 02-20-2005, 09:38 AM
afelix9137 afelix9137 is offline
97 Blazer HELP!
Blazer has 158,000 miles. oil changes every 3,000 miles. Blazer runs good except when going uphill. SES light blinks then stays on, can't go more than 10-15 mph uphill. SES goes off after couple cycles of new gas. Had ignition switch replaced. Had tune-up. Had PCV valve replaced. Had oxygen sensor placed. Had injector service.
Codes found were P0300, P0151. Any ideas on what to do next? Don't say trade in.
Old 02-20-2005, 10:31 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Blazer HELP!
Clean your MAF sensor with TN cleaner and a gentle toothbrush and get the black crud off of the two small sensor wires. BE GENTLE!
Check fuel pressure?
Did you replace the fuel filter?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-20-2005, 11:22 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 97 Blazer HELP!
P0151 = HO2S Circuit Low Voltage Bank 2 Sensor 1
Old 02-20-2005, 02:17 PM
BlazerLT's Avatar
AF -Advisor
Re: 97 Blazer HELP!
Yes, but the MAF sensor if dirty will cause O2 sensor codes as well.
Old 02-20-2005, 02:21 PM
blazee's Avatar
Problem?
Re: 97 Blazer HELP!
I was only stating the code for those attempting to help. When I tried to look it up in my Haynes manual, it wasn't in there. I had to do a web search to find it.
Old 02-20-2005, 02:24 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 97 Blazer HELP!
Oh, ok , I see. No prob. Was just letting him know before he swapped it out and found that it didn't fix the problem.
