Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-20-2005, 08:12 AM
nbgc99 nbgc99 is offline
Question code 43
Help, my 99 GC check engine came on and I was able to decode it to a code 43 (misfire). Engine runs OK, not 100%. Can anone point me in the right direction to fix? I'm thinking plugs and wires...
Old 02-20-2005, 08:51 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: code 43
If u have it scan with a scan tool it can tell you a more detailed code (it could pin point the cylinder that is missfiring). You can get it scanned for free at Autozone.
Old 02-20-2005, 11:09 PM
porscheguy9999's Avatar
porscheguy9999 porscheguy9999 is offline
Send a message via AIM to porscheguy9999
not that you would, but you could buy a decoder for like $100. Which isnt very bad, if youve had problems before. I believe they work on all brands of cars. or you could buy one for about $200 and it gives you a detailed readout of the problem (i.e. what cylinder is the source of the problem). This post probably doesnt help you any, but its an idea.
Currently:
1998 BMW 328is black/black coupe 5MT
Thanks to Nicecar!
Got a Facebook? Join the AF group!
http://hs.facebook.com/group.php?gid=2213949483&ref=mf
Old 02-20-2005, 11:26 PM
Bob D. Bob D. is offline
Re: code 43
I think you should recheck that code.
If its a 1999 Jeep Grand Cherokee the description for a code 43 is -
Shorted condition detected in the oxygen sensor heater element control feedback sense circuit.
http://www.wjjeeps.com/faultcodes.htm#0010
Old 02-21-2005, 03:20 AM
Re: code 43
it's not an OBD II type code, it's the CHECK ENGINE light flash code - count the # of flashes the check engine light flashes.
Those codes are specific for a DRB (Digital Readout Box) Scanner.
If he used a scan tool it would actually come up as P0300, 0301, 0302, 0303, 0304, etc or if it was displayed on a digital odometer it would look the same way. which would tell exactly which Cylinder was misfiring.
Old 02-21-2005, 04:57 AM
Re: Re: code 43
Well, something seems amiss here-- if its a 1999 Jeep Grand Cherokee he should be able to use the OBDII, key on off method to retrieve the p**** error codes on the OD.
The flash count (OBDI) method shouldn't even be available on a '99>
Old 02-21-2005, 06:13 AM
Re: code 43
that might be true. Didn't think about it.
Old 02-21-2005, 07:19 AM
mikec041 mikec041 is offline
The 99 gjc has a digital odo. readout, also the code is cylinder spicific.
I have a 99 w/4.0 that misfires on #3 cylinder a couple times a year for what appears no reason.
Old 02-21-2005, 09:07 AM
Re: code 43
theirs only one way to find out.......
NBGC99 - How did u get this code (code 43). was it displayed as code P0043 from a DRB scan tool from the dealership or mechanic? or was it extracted using the CHECK ENGINE light flashes or digital odometer.
I guess we're are all a little confused on this one.
Old 02-21-2005, 10:51 AM
Dale Aeppli Dale Aeppli is offline
Re: code 43
http://www.wjjeeps.com/tsb_list.htm#0900303 HERE TSB THAT YOU CAN CHECK ON DALE
