Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-20-2005, 04:51 AM
PHAREAL PHAREAL is offline
security
i have a 95 olds my security light stays on, and the car wont start. i waited to 3 mins. to see if i would get the dirt key message but i didnt. what could be the problem?
thankx in advance for any information.
Old 03-29-2005, 10:27 AM
The Rebel The Rebel is offline
Re: security
WoW car won't start? I had a similar problem...
I lightend the load on my key ring to just the start up key & trunk & key fob. No other keys, because this extra weight causes the key chain to (hang) out of the ignition switch, causing the SECURITY light to come on.
Old 03-29-2005, 08:42 PM
KJH KJH is offline
Re: security
I had the same problem so I cleaned the chip on the key and checked the fuses under the rear seat. In the end, the ignition switch was the culprit. Good luck!
Old 03-30-2005, 09:37 AM
IT Geek IT Geek is offline
Re: security
The security system relies on the little resistor in the key, as well as contacts in the ignition switch and a couple of small wires from that to the computer. If there is a problem with any of these, the engine will not start. The computer has to measure the resistor in the key and determine if it is the correct value, before instructing the PCM that it is OK to start the engine.
Unfortunately, there isn't an easy answer. Do you have a spare key, and does that act the same? If it does, then you likely have a problem with the ignition switch, or the wires that run from the key contacts to the computer.
Old 03-30-2005, 10:25 PM
Re: Re: security
way to go, Newbie ITGeek...and welcome to the Automotive Forum!
Old 03-31-2005, 02:34 PM
Re: security
I've been poking around on a couple of these forums lately. I recently purchased a 95 with 152K miles from a friend of my mom's. The information that I found in this forum was especially helpful in making my decision because I'm a real DIY mechanic and felt confident that I could tackle just about everything that one deals with on this car. I was also able to do an extended test drive (a couple of days), and really checked the car out in advance.
Anyway, I only paid $2000 for the car and have put about $1000 in parts into it. The labor was free, of course. I'm now down to look and feel stuff for the most part, so I'd say I've gotten a great deal for about $3000. For a guy of my means, and four kids, the Aurora is about the only way for me to have a luxury vehicle. Here is a quick laundry list of things that I have done:
- Both front wheel hub assemblies
- Both front swaybar links (when doing the hubs)
- Radiator inlet tank
- Alternator
- Power steering pump
- Serpentine belt
- Throttle body vacuum line assembly
- PCV bushing
- Front control arm bushings
- Idler and tensioner pulleys
- Plugs and wires
- Fixed broken rear door handle
- Fixed driver's lumbar seat
- Fixed broken wires in driver's door
That's about it at this point. The only other mechanical issue is the ELC compressor not shutting off. There is probably a leak in one of the air lines, but the weather around here has not gotten decent enough for me to get under the car and really diagnose things.
So, when you add up the repairs, it would have cost a small fortune at the dealer. I've been able to do everything listed for under $1000. Now I've got a car that runs great, rides great, and looks pretty good.
I'm starting to work on undercarriage items like the wheel wells. I've been cleaning them one at a time, priming where necessary, and applying new undercoating. It makes sense to keep this beauty from rusting out. When I worked on the radiator, I took the extra time to clean, prime and paint the body structure under the radiator, as well as the front part of the powertrain cradle. It's not a lot of extra work to do this sort of this thing, doesn't cost a lot, and helps to keep the car from rusting.
I'm starting to work on the paint to deal with chips and scratches. This car was driven quite a bit, and the body is showing it in places. If I can get the paint looking good, then I will have a car that looks and drives almost like new.
I enjoy passing on tidbits that I have found in doing my own repairs for those who are up to doing some of their own repairs instead of going through the dealer. In some cases, you need a pretty complete set of tools to do the work. But you can rent some of the really exotic numbers for free at some auto parts stores. Having the factory service manual is also really important for the DIY mechanic. I was lucky, because the manual set for the 95 can be gotten for $30. Once you get into 96 and up, you're looking at over $100.
I've posted a pretty extensive write-up on replacing the radiator tank. And will continue to post these kinds of things when doing repairs that other DIY guys might find helpful. The parts costs for this car can definitely be higher, but it is still the labor that kills you.
I think that the Aurora can be a great vehicle. Unfortunately, there are some common issues with these cars that can be very costly. But you don't get something for nothing. If you are buying a car that cost $30K to $40K for $2K to $5K, then you should be prepared to pony up the money and the time because you will spend it for a car that looks this good, but has this kind of depreciation. I think that GM rushed this one, got kind of cheap on some of the materials, maybe a little of both. It is a great deal for those of us that can do alot of the work ourselves. For a car that performs like this, I'd wouldn't even thing of doing anything differently.
Old 03-31-2005, 08:55 PM
Isnibs's Avatar
Isnibs Isnibs is offline
Check out
http://www.automotiveforums.com/vbul...55#post2953555
1996 Aurora Black / grey
Old 04-01-2005, 01:41 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
well its been awhile since I've been on here, No one has been able to help me with my car, I've tried everything. I've done almost all the trouble shooting with my car, It just wont start. When it does start it runs fine. But the security light flashes constantly But before it all stopped working I was getting a pass key II system fault, there is nothing in those aurora books that talks about that. I've been out of a car for 3 months. Im not sure what to do. Im thinking about just buying another one, but since Im in such finacial trouble because of the winter and having no work it just sucks, man if anyone can help me. The only trouble shooting I haven't done is the one on page 8-714 on the 99 books it might be the same with the others. "security indicator always on or flashing" I need Gm tools to trouble shoot it and now GM is charging 90 bucks per hour to work on the dang car so Im pretty much screwed from this point. I've replaced the starter, ignition switch, theft deterrent relay, battery, pnp, and Checked wires i've done everything. someone give me some info please
before this all happened I also had the problem with the car sometimes starting and sometimes not. Then all of a sudden it would start.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-02-2005, 11:56 AM
Re: security
well im just buying another aurora for a grand so therefore the money I wouldn't have put into fixing the dang thing I just was able to buy anther car. lol Now I have parts or maybe later I'll put it in the shop to fix.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-02-2005, 09:12 PM
Isnibs's Avatar
Re: security
I hope this doesn't sound daft but did you ever reset your ECU?
Old 04-02-2005, 09:29 PM
Re: security
yep
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-03-2005, 10:02 PM
zacuda zacuda is offline
Re: security
I had trouble with my VATS system. I took it to an alarm shop after reading this post and had them bypass the VATS. Car starts every time now.
Rich
http://www.automotiveforums.com/vbul...highlight=vats
Old 04-03-2005, 10:53 PM
Re: security
do you know how they bypassed the vats, and how much did it cost you to get it done?
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-04-2005, 10:55 AM
Re: Re: security
They put in a resistor so the VATS thinks that the key is in all the time. It was $50.00. Any car alarm shop should be aware of the procedure because they have to do it to install remote starting systems on these cars. The downside is when the ignition switch turns the car will start. No more VATS protection.
Rich
Old 04-04-2005, 12:27 PM
Re: Re: Re: security
Rich
I hope your not talking bout , that the car will start in any gear?
This is very dangerious should you forget that the car is in D or R
(in a shop) and the mechanic starts the vehicle!
