Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-20-2005, 03:14 AM
pipelinerr pipelinerr is offline
Send a message via AIM to pipelinerr
95 suspesion clunking
i have 2 95 4x4s. both clunk when loading and unloading the suspension [as when turning in a driveway ] 1 on the pass side the other on the drivers all ball joints and bearings replaced. i believe the torsion bar adjuster lever is the culprit anybody have same problem?
Old 02-20-2005, 05:49 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 95 suspesion clunking
Could be the bushing on the torsion bar, could also be the hubs
Old 02-20-2005, 10:38 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
do a search in the blazer forum for clunk fix, you might need the new hood washers.
I have a 1995 and it fixed my clunk.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-20-2005, 06:25 PM
had bar out what bushing? play on lever
Old 02-20-2005, 06:40 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 95 suspesion clunking
Prop you hood up grab the hood hinge with your hand, shake the hood front to back and listen for a knocking noise.
LISTEN TO ME!
Old 02-21-2005, 08:35 PM
did what you said no play on p/side play on d/side plastic panel had screw missing on p/side when i bought truck might have been addressed this is popping [ loud ] when the body rollls side to side not a rattle when going over bumps gmotors.com [ dealer in fla ] has the adj.lever for torsion bar for $25 any other "cheap" sources for gm parts?
Old 02-21-2005, 08:47 PM
BlazerLT's Avatar
AF -Advisor
Install the hood washers before you do anything.
Trust me on this. Just do it. It costs under 10 bucks.
http://www.automotiveforums.com/vbul...ight=clunk+fix
Old 02-22-2005, 07:22 AM
GeneP GeneP is offline
YUP, Just like Blazerlt says, it was the hood hinge on mine too. His past recommendation saved me lots of $$. I would have never thought all that clunking came from the hood hinge and it did sound like it was the suspension.
Gene
