Old 02-19-2005, 11:56 PM
91p10nizmo 91p10nizmo is offline
stripping body
Hi
does anyone have an easy way if stripping the body of all its parts without breaking them? and do you use brake fluid to strip the paint?
thanks Nathan
Old 02-20-2005, 01:01 AM
RallyRaider's Avatar
Zomby Woof
Re: stripping body
If you mean stripping the paint off, there are lots of options:
oven cleaner
CSC
brake fluid
91% isopropal alcohol
Easy-lift Off
All basically involve soaking the body until the paint crinkles or starts to dissolve, then you scrub into the crevaces with a toothbrush or similar. As most are caustic you'll need to wear gloves. Some will affect the plastic to a greater or lesser degree, so only soak as long as needed.
