Old 02-19-2005, 11:00 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
Arrow wheels wheels wheels!
what is the offset on the base 93 stealth's? is it ok to put a wheel with a 38+ offset on? and also what is a better fitt a 225mm wide tires on a 17"x7" wheels or 225mm tires on 18"x7.5"?
Old 02-20-2005, 12:41 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: wheels wheels wheels!
I would never have a 7" wide 17" or even 16" wheel on a 3s. If you go with a 17 go 245/45 or 18 go with 245/40. You will love the added width and the look it gives the car. I ran some 245/50/16's and it looked great. As for the offset I am not 100% sure.
Old 02-20-2005, 06:20 PM
isnt 245 a bitt to much on a base stealth? i remember when i was using 225/45 and i culdnt even make the tires spinn
Old 02-21-2005, 08:49 AM
Stealthee's Avatar
Re: Re: wheels wheels wheels!
Well if I remember right you said you were automatic. In a base auto its hard to make the tires spin anyways. I can turn 245's over no problem. They make a nice smokey burnout.
Old 02-21-2005, 09:25 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
225 width is stock, but IMO its too narrow. i say at least 245. 255 would be very nice. as to Stealthee's suggestions on the sidewall measurement, if you plan on enjoying the handling capabilities of the 3S, then i wouldn't go below 45, 55 to be safe.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-21-2005, 10:29 AM
i am thinking of going with 18" 7.5"wide wheels with 225/50 tires do you guys think that will fit without any problems. im just worrying about if the tire does not fit or hits something. and actualy on a base stealth the stock size is 205/65
Old 02-21-2005, 01:52 PM
i forgot to ask... is the brake system on the non turbo 3k gt's the same as on the eclipse?
Old 02-21-2005, 05:44 PM
Stealthee's Avatar
Linebacker. for 18's 245/40 is the stock height tires for 3s's. 245/45/18 is taller than stock.
O & G 225/50 is actually too tall for 18" rims. You will not have any issues what soever running 245/40/18's. 7.5" width is ok and you will not rub. Hell there are a few guys who have 19's and I even saw one on 20's. The base Stealth is the exact same chassis as all the NA 3s's.
As for the brakes I heard that our brakes are actually upgrades for DSM's.
