Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 02-19-2005, 09:24 PM
LorenzoM72 LorenzoM72 is offline
1991 B2200 timing question
Anyone know what are the timing marks for a 91 B2200?The repair manual calls for "A" mark on the camshaft pulley, but I don't have that. I have #1, #2, #3 and #4 with an arrow above each at 90 degree from eachother, and I also have a circle between #1 and #4. What mark should I align to the mark on the housing?
Any help is greatly appreciated.
Thanks.
Old 02-20-2005, 10:39 AM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
with the crankshaft pulley lined up at zero in the lower timing belt cover,
camshaft pulley #1 or A mark should be lined up with the upper mark on the aluminum back plate housing.
Old 02-20-2005, 12:20 PM
The lower timing belt cover is off, and so is the big pulley on the crank shaft. Now, the small pulley on the crank shaft (timing belt pulley), has a notch on the back side, and a circle on the front side, right above the key of the crank shaft. I aligned this mark, to the mark on the housing...at this point, what mark on the camshasft pulley should align with the mark on its housing?
Thanks in advance.
Old 02-20-2005, 03:08 PM
if the bottom timing belt pulley is lined up with the housing mark, that's good.
Now the camshaft pulley mark #1 should line up with the housing mark on the top.
Then you're good to go.
Old 02-20-2005, 10:31 PM
Yeap, it worked! Thanks a lot for the help.
Old 09-24-2005, 09:44 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
Re: 1991 B2200 timing question
B2200 / 2000 Timing Check
Owner of Mazdatruckin.com
Old 04-28-2006, 10:40 PM
grandmaster_mel grandmaster_mel is offline
I have a problem putting the camshaft sprocket (top timing pulley) back on because I did not mark its position prior to removing it. There is a guide pin on the camshaft that mates to this sprocket. Does anyone know what position this guide pin should be if the crank pulley is already at TDC (12,3,6,or 9 o'clock) ? There are 4 positions that this guide pin can go on the camshaft sprocket. If I only know the actual position of this guide pin at TDC, based on previous form on timing issues, the #1 marking should be at 12 o'clock position. Anyone?
Old 04-28-2006, 11:05 PM
Looks like the guide pin is at 12 o'clock position. Thanks!
