Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-19-2005, 07:06 PM
Bob CV Bob CV is offline
Bad lifter
My son has a 96 Crown Victoria with the 4.6 engine. It has stated to make a awful noise that the NAPA guys think is a lifter ( hydraulic compensator) I have never has one of these apart, nor do I have a manual for it. Can anyone give me some insight on how this is put together? If anyone has a manual on CD could you send a picture or two out of the manual?
Thanks
Bob Wilson
Old 02-19-2005, 09:27 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Bad lifter
Thanks
Bob Wilson
This theory is possible, but doubtful because you do not mention an "engine misfire" code being stored.
I tried to upload a photo, but apparently this site does not allow .jpg images?
Also, they are called "HVLA"s for Hydraulic Valve Lash Adjuster, and they do not make the typical "lifter noise" like you get on an pushrod engine, not at all. He may very well have a failed timing chain tensioner. Does it sound like a sewing machine at idle? If so, that's it.
Old 02-20-2005, 06:53 AM
Re: Re: Bad lifter
It could maybe considered a sewing machine noise on steroids. It does change with RPMS, sometimes the noise will stop. It will also change in volume and frequency when put in gear.
Old 02-20-2005, 03:35 PM
ModMech's Avatar
Re: Bad lifter
If it sounds like more than one event per revolution, then it is most likely a timing chain tensioner gone bad. While this is not at all common, it does happen, and it also requires the front cover to be removed for the repair.
Old 02-20-2005, 05:17 PM
ModMech,
I sent you a PM about sending you a MP3 of the noise but I need your Email.
[email protected]
Bob W
Old 02-20-2005, 05:31 PM
ModMech's Avatar
Re: Bad lifter
I don't do MP3s, or any other internet downloads, sorry.
Old 02-20-2005, 06:43 PM
Re: Re: Bad lifter
No problem. The noise does seem to be more often than once per revolution. And it will stop making the noise for a bit then start again.
Bob W
Old 02-20-2005, 10:54 PM
ModMech's Avatar
Re: Bad lifter
Unfortuneately, that does seem more like a tensioner than a HVLA. The "good" part, is that it is really not at all difficult to replace the tensioner(s), especially on the '98 up cars w/o mechanical fans.
Old 04-18-2005, 12:25 AM
toxicity61284 toxicity61284 is offline
Send a message via AIM to toxicity61284
Re: Re: Re: Bad lifter
Bob W
Have you thought about it maybe being carbon buildup in the engine?? my 94 grandmarquis made a ticking noise and it would speed up as i pressed on the gas,, ended up being carbon buildup in my cylinders.. all i did was dump in fuel injector cleaner, filled it up with premium gas, and took it up to a slow steady 65mph on the highway,, and cleaned it out...
hope that helps
Old 04-24-2005, 08:33 PM
radioman2002 radioman2002 is offline
How about something even simpler. maybe the fan belt idler. I have had quite a few go bad, some squeal, some chirp, and some only act up when its cold. Try removing the fan belt and spin the idler, if it makes noise chances are thats the problem. Also with the fan belt disconnected, start the car, but don't run it too long and see if the noise is still there, if so look towards an engine part. BTW the overhead cam engines don't have a hydralic lifter.
