| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
6.5L diesel chevy fuel pump
Where can I get info on how to replace the fuel pump on a 1996 Chevy C3500 pickup with a 6.5L diesel? Any help would be much appreciated.
I've never worked on a diesel before and I think $2300 to replace it is absolute robbery, considering I found a pump for $90 |
Re: 6.5L diesel chevy fuel pump
Buy a repair manual for your truck. Even if you only use it once, it is well worth it. I believe most diesels have a low pressure fuel pump in the tank that delivers fuel to a high pressure pump under the hood. Make sure you have the right pump (assuming there are two, I'm not absolutely sure there are two)
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
