Old 02-19-2005, 04:32 PM
paulpfiction paulpfiction is offline
Problem with my gas mileage
couple weeks ago i drove up to school in my chevy blazer. a 600 mile trip, i got 315 miles before i decided to fill up. well i get up there, spend a night, then the next day my fuel pumps goes out
so i take it to a shop and they replace the fuel pump, and the put in a new pulsator and what not, well now i am getting about 200 miles per tank
my last tank i went 203 miles and put 15 gallons of gas in, meaning i was getting 13.5 miles per gallon.
any idea on what is causing this? i need to get this fixed, but i dont know what to tell them to fix, when i went back to them they just said, "all we did was put a fuel pump in, nothin we did should affect your mileage"
but it was fine the day before i took it there
Old 02-19-2005, 04:59 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Problem with my gas mileage
You are talking about a 95...right?
Is it running bad? Check engine light? When was the last time it had a tune up? When it is warmed up, what does the temp gauge show? be specific.
If you ran the tank low enough to suck up trash and burn up the pump, you could have clogged the fuel filter or injectors.
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
How about a tune up?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-19-2005, 07:01 PM
Re: Re: Problem with my gas mileage
i dont believe it's been that long without a tune up, but why was it running fine before it got fixed, and now after the pump gets replaced, it doesn't run fine?
i mean im not talkin like a week after, or a week before
its a difference of the exact moment i gave it to them, and the exact moment i got it back from the change in mileage
and ill start checkin the temp gauge and no the check engine light is not on
Old 02-19-2005, 07:17 PM
BlazerLT's Avatar
AF -Advisor
You don't "believe" it has been that long? Don't assume anything about your truck until you are sure of it.
Could be with the added pressure and proper fuel flow you spark plugs can't handle the proper combustion.
Also, did the guy replace the fuel filter?
I would reset the computer by pulling the negative battery cable and removing the two ecm fuses to reset the computer so the computer can relearn the fuel curve again faster.
The computer could have been retarding the timing because of the lack of fuel flow and now that the fuel flow is 100%, the timing could be a little retarded and rich. Resetting the computer should fix that quick.
Old 02-20-2005, 10:33 AM
normal, 210, right in the middle, little below
Old 02-20-2005, 10:37 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Problem with my gas mileage
That is normal.
Did you read my last post or are you just ignoring it.
Old 02-20-2005, 10:39 AM
Re: Re: Re: Re: Problem with my gas mileage
That is normal.
nono, i was going to find out this stuff. it is my bro's car. so he would know when the last tune up was, but i had to work till 3 am last night, so i didnt get a chance to call
and i have the receipt in the car which i will check this mornin if the fuel filter was replaced
and can you tell me what an ecm fuse is?
i was goin to try that tonight when i got home
Old 02-20-2005, 10:44 AM
BlazerLT's Avatar
AF -Advisor
it is in the fuse panel on the driver's end of the dash.
Open the door and you will see it on the side.
Old 02-20-2005, 12:40 PM
500 500 is offline
The pickup is in the bottom of the tank where any trash would be no matter what the fuel level.
500
Old 02-20-2005, 01:49 PM
blazee's Avatar
Problem?
500
Thank you for clearing that up. I always thought the pick up was at the top of the tank. Does this mean I can stop filling up every 4 miles?
