Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-19-2005, 03:18 PM
koda1118 koda1118 is offline
92 explorer not charging/replaced alternator
92 explorer rebuilt alternator / check output ok however it is not charging replaced wiring plug still not charging correctly
Old 02-19-2005, 08:33 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: 92 explorer not charging/replaced alternator
Did you charge the battery fully before you put on the alternator. Should have taken 3 or 4 hours probally.How old is the battery? Have it load tested if it doesn't charge up. It doesn't matter how old it is, that could be your problem. good Luck
Old 03-16-2005, 01:56 PM
catsfan catsfan is offline
Were you able to diagnose the problem?
I'm experiencing similiar issues with my 2001 XLT. My battery gauge still reads low even though my alternator, battery and coil have been tested and or replaced.
Old 03-29-2005, 02:54 PM
92woes 92woes is offline
Thumbs up Not charging
I ok i just went through this with my 92 explorer ,, open your hood, find your power distrabution box on the pass. side i think. open it, see all the big fuses? well on top there`s two blue #15`s check them one is alt.charge ,,, that should be it. replace it , check your batt. gauge now!!
