Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 02-19-2005, 03:08 PM
cunokyle cunokyle is offline
Send a message via AIM to cunokyle
93 Villager erratic running
I have a 1993 Mercury Villager with 180,000 miles on it. A few months ago it began to idle erratically and then began to run like crap all of the time. It would act like the catalytic converter was plugged when you gave it gas on hills and such and would lose power.
I changed the cat and it still happens. Since then I have changed the cap, rotor, distributer, plugs, wires, fuel filter, fuel pump, and air filter! It still runs like it is missing horribly. I have checked the timing and that does not appear to be the issue.
The check engine light is not on.
I have a code reader but am not sure where it plugs in. I have looked all over in teh engine compartment(that is where the manual says it is located).
Any help here with the problem or locating the scanner plug point is greatly appreciated!
Old 02-20-2005, 07:34 PM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Its located on the dash if what your looking is for the CEL sensor codes. In the engine compartment I am not sure there is one.
Old 02-20-2005, 10:45 PM
Re: 93 Villager erratic running
thanks...any idea where in the dash I should be looking for it?
Old 02-23-2005, 07:37 AM
ok, I have now replaced the mass airflow sensor...and that did not help either.
Old 02-23-2005, 07:39 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
if your check engine light hasnt came on you wont have a code stored. youll only have a code if the light comes on. have you checked fuel pressure? dirty injecters? how about coilpack, pick up coil? check all vacuum hoses.
i wish there was a way to record the sound of it
and play it back on this forum. it sure would help.
good luck.
Old 10-14-2005, 02:44 PM
campsc campsc is offline
Had the same problem with mine (355,000 KM and still ticking).
Try changing the O2 sensor. Worked for me.
Good luck
Steve
Old 10-17-2005, 07:05 PM
IH8SPM's Avatar
Does it idle well and rev strong in park? You may have a bad throttle body or Tps throttle position sensor or a dirty throttle body. Remove the air filter and then the the hose that goes to the air intake and look for build up. Carbon deposots can accumilate and cause the throttle to stick therefore giving the transmission a false signal and not providing the right gearing for accelaration.
Old 10-26-2005, 06:54 AM
Update:
Ok...the timing belt is not the issue...it still runs like crap. It idles a little better, but but it still runs like it is missing badly. I have no idea what is wrong with it now. Time to call the junk yard.
Old 12-02-2005, 10:23 PM
dunmowdan dunmowdan is offline
Send a message via ICQ to dunmowdan Send a message via Yahoo to dunmowdan
Does any one know why my 1993 engine will not start. I have checked the battery and can get power to the Solenoud adn teh starter motor and it will only start if I put a battery-charger power-booster on. There is a clicking noise (when I do get it going while I am attmepting the strart it, in a black box at the left rear of the engine compartment (looking into the engine from the front).
Is there a relay or something else between the ignition starter switch and the solenoid?
Old 12-03-2005, 07:49 PM
IH8SPM's Avatar
Is there a loud buzzing or humming sound coming from your car. You may have a bad fuel pump. This will definatly cause your problem. The junk yard does not need you van yet. Post back update.
Old 12-03-2005, 10:24 PM
Re: Re: 93 Villager erratic running
The fuel pump seems to be working fine. I have not checked it with a pressure gauge, but removing the hose from the fuel filter then turning on the key results in a good flow of fuel through the hose.
Old 12-04-2005, 11:33 AM
IH8SPM's Avatar
If you open a bottle upside down it will flow but aventually it will start to flow slower as the pressur increases. You need to check the basic stuff.
Is your throttle body clean? Is the TPS working or set correctly. Is there any obstruction between the air box and the intake maifold. Is there a broken cable for the sparkplugs(i now they are new) Do you have coolant. There are tons of things to check that are fast and easy and require no parts to replcae. I would go to the van and start it up. Let it run for about a good half hour or an hour to get it to normal temperature. Then I would rev it up in park no more than 3000rpm. Then I would check if it reced good I would set the parking brake and make sure the van it facing open road and not a house if you know what I mean. Then I would try to get the van to move in drive while the brake is set. It should be able to. If there is any stored code in the tranny or tps this should trigger it since the gas pedal will indicate that the throttle is open and the car is still not moving at the same pace. This will also put a larger strain on you fuel pump and if it stalls you should replace it once you verify that it is the fuel pump. There is a way to test every thing I mentioned in the haynes manual.
One more thing have simply just checked to see if there is dirt in the one of the many plugs leading to the throttle parts?
Old 12-04-2005, 12:09 PM
Thanks for all of the suggestions...a couple of quick things...
It does not idle good when revving it up in park at 3000 rpms...it fluctuates and will not hold a steady rpm(due to it missing). The fluctuations are not rythmic...it is uneven and sputtery..if that makes sense.
If I stick the van in gear, hold down the brake, and give it gas, it wants to try to move...it will die if you give it gas past a certain point.
The engine coolant is full. I have pulled off the air intake, and made sure it is clear of obstructions, plus I replaced the air filter. As far as I know the TPS is working corectly...is there a way to effectively test it? I have cleaned the throttle body as well.
I would hate to go through the hassle of changing out the fuel pump and it not be the problem...I have spent more time on this problem than I would like to admit and am honestly about sick of dealing with it.
Old 04-03-2006, 01:44 PM
Richz54 Richz54 is offline
I have a 1993 Villager with 171,000 miles and it seems like the same problem as your. Did you find the problem?
Old 04-03-2006, 07:58 PM
I would suggest changing the timing belt as I am sure that is what the problem was. We did not get it fixed on time and it broke and then messed up the valves in the engine. If you have the same engine we did, valve clearance is an issue if the belt breaks and the valves will get bent.
