Old 02-19-2005, 02:20 PM
capritoms's Avatar
capritoms capritoms is offline
Which is faster?
I have a friend with a 93 hb 1.0 5 speed that has 80000 miles and I have a 96 hb 1.3 AT with 160000 miles and neither of us have any performance mods done to them...I have replaced both front axles and both of our cars easily pass emissions checks but my question is who would win in a drag race and what 1/4 mile times could be expected from each combination?
Thanks
Old 02-19-2005, 05:29 PM
SeanMurphy's Avatar
SeanMurphy SeanMurphy is offline
Re: Which is faster?
With both vehicles in similar condition, I'd wager that the 1.3 would win. The small auto trans isn't nearly as laggy as some older transmissions for bigger cars, plus an auto CAN give you a better launch if you're not used to power launching a stnadard. The extra power of the 4 cylinder would probably get you down a strip a few tenths faster than a 1.0 standard.
Though on the flip side, you could run the standard out to a higher rpm before shifting, giving you quicker accelleration, though past 5500, the 1.0 doesn't give much more power, just makes more noise.
02 Chevrolet Tracker 4WD
Old 02-19-2005, 05:49 PM
absolut_vodka absolut_vodka is offline
I would go with the 1.0 Manual.
Old 02-20-2005, 12:39 PM
geozukigti geozukigti is offline
I'd go with the older 1.0 also. I had a 91' metro convertible 1.0 auto, that beat my buddy's 95' 5 speed metro. The MK4+ metros were a wee bit heavier. I'd expect about a 17.8-18.2 1/4 mile.
Old 02-20-2005, 08:57 PM
SeanMurphy's Avatar
The convertables had a lower gearing to compensate for the added weight. I'm not sure if it was just top gear that was modified or if it was the first couple gears too.
Old 02-23-2005, 07:07 AM
avfan avfan is offline
What was your top speed in the 1/4? Someone posted here that they did a 42 second 0-60 that seems a bit high even for a 3 cyl metro with a couple bad valves and a dead tranny!
Avfan
94 geo metro 200k 1l
89 ford probe lx 150k 2.2l
76 Ford F150 w/390 edelbrock performer series 4bbl 4x4
Old 02-24-2005, 03:50 PM
capritoms's Avatar
Track opens in April and I will post the results of the race then
Old 02-26-2005, 11:27 PM
fc735 fc735 is offline
16.5@49mph in the 1/8
Old 02-27-2005, 09:53 AM
SeanMurphy's Avatar
That big ol' whip antenna you got on it must be dragging you down a couple thousanths
Old 03-30-2005, 08:00 AM
Ge0Sc0ut Ge0Sc0ut is offline
Send a message via AIM to Ge0Sc0ut
Re: Re: Which is faster?
HAHAHAHA Omg someone should hold a Geo race....hahaha and see who has the best running Geo around here....Of Course there would be rules and regulations for which Geo Vs. Geo type situation
I'm saving that picture and giving it to my friends cause all Geo's rock!
