Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-30-2001, 05:31 AM
maximalian maximalian is offline
Question tires pressure
hi guys, i have a question, i have16'' stock rims, a looked the manual, it say the tire pressure should around 30-32, but heard some ppl said between 25-27, do u know which 1 is rite?
please help
Thank you!
Are u......Maximalians? ^_^
Old 06-30-2001, 05:56 AM
4 MAX FUN 4 MAX FUN is offline
The book says 32lbs. You should consider this as your minimum!
Slightly higher pressure (up to 34-35 lbs, will improve your handling, improve your gas mileage, improve your resistance to tire damage from potholes, reduce your tire wear, and give you a slightly harsher ride. Running 1-2 lbs higher in front then in back will also help cancel out some of the understeer that virtually all front drive cars, like our Maximas, have.
Even a pound or two below the factory recommendation will degrade all of the factors above, and make you more subject to a tire failure. Remember too that tire pressure should be measured "cold" (i.e. with less than a mile or two of driving), and that tire pressure can drop 4 lbs or more as you go from the summer to the winter months (about a lb for every 15 degrees of temp drop).
I run my 2000 Maxima SE at 34 front, 33 rear on the street, and 42 front, 36 rear on the autocross track. On my previous car (a 93 Honda Accord) I got longer tire life on a car that went to the race track 1-2 per year, running, high performance (and therefore shorter tire life) low profile tires, then many people get out of the stock tires, running similar pressures, and keeping very close tabs on tire pressure.
-Bill, aka 4 MAX FUN
"Racing's Great...at the Race Track!!!"
Old 06-30-2001, 07:01 AM
Smile Thank You!!!
4 Max Fun,
Thanks for your helpful info, I really learn alot, Thank you very very much!!! :flash: :sun:
Old 07-07-2002, 04:56 PM
jkmay01 jkmay01 is offline
Send a message via Yahoo to jkmay01
Question what is the recommended tire pressure
what is the recommended tire pressure for my 89 nissan max with stock rims and tires 205/65/15 ? the book seems to say 32 psi?? help me???
Old 07-09-2002, 02:20 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
*shakes head*
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 07-13-2002, 04:26 PM
Mikie's Avatar
Mikie Mikie is offline
If I am correct (and I know I will be corrected if I am wrong...)
the proper tire pressure is listed on the tire itself as well as (at least for the 2k3) inside, on the top of the armrest. I quote from the manual:
"TIRE PLACARD
The cold tire pressure is shown on the tire
placard affixed to the console box lid."
2003 Maxima GLE Grey Lustre
Old 07-13-2002, 05:55 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
if ya that hardup, jus look at the tire, it will be pretty obvious if there isnt enough air in the tire
Old 07-15-2002, 07:22 PM
RALMADA RALMADA is offline
Lower air pressure increases rolling resistance, your car consumes more gas,
Lower air pressure increases the temperature, as the tire side walls bend more, decreasing your tire life.
Lower air pressure lowers the performance of your tire
BUT !!!!
Be careful not to pass the max pressure indicated in your tire, remember that pressure indicated there is THE MAXIMUM, which means in hot conditions, or whatever extreme conditions.
Clean you tires perfectly, inflate them to 32, and go for a hard drive, when your back, see if you used all the thread in the tires, if you used part of the side wall, you need to increase the pressure one or two psi
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
