Old 02-19-2005, 12:59 PM
DartFart DartFart is offline
318 in a Dart?
Is this a good performing engine for a 67-69 Dart? Are the parts readily available and is the engine reliable?
Old 02-19-2005, 01:07 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 318 in a Dart?
The cars were light enough but not really a performance car with that engine.
Engine reliable? Probably the best engine ever made for a car...
My Mopars
Old 02-19-2005, 04:15 PM
Re: 318 in a Dart?
Could the 318 be modified to produce a bit more performance and would this be a good route to go for a daily driver with some performance in a Dart?
Thanks
Old 02-20-2005, 02:16 AM
71Cnet 71Cnet is offline
Re: 318 in a Dart?
the 318 is the second most bullit proof eng made. 327 chevy being first but not important. my friend has a 318 in his 73 dart and it is a good driver and somthing that can be taken down the strip. its a good eng and a light car you will have no problem finding parts. mopar performance is the easiest place to find parts but not the cheapest. P.A.W. (performance automotive warehouse) is pretty cheap but doesnt really have a big selection but for the parts you are going to need it will be perfect. if you need anything else let me know.
So how many chevy's and ford's does it take to beat a MOPAR? The world will never know!
Old 03-22-2005, 07:01 PM
turbo maxima's Avatar
turbo maxima turbo maxima is offline
Send a message via AIM to turbo maxima
Re: 318 in a Dart?
those engines are pretty nice, i had one in my 73 swinger, they are pretty quick, the engine from 72 put out like 250 stock i know, and parts are not too hard to find, u can easily find an intake and carb to help ad some perfomormance to it, if u want a really nice small block though i recomend the 340, they can handle more power then any of the other small blocks
Old 04-06-2005, 05:36 PM
BleedDodge's Avatar
Re: 318 in a Dart?
In '72 it would have only been making 150 horse stock.
My Mopars
Old 04-13-2005, 06:27 PM
Re: 318 in a Dart?
i was gonna say mine only had 230hp in 71
Old 04-14-2005, 07:44 AM
MrPbody MrPbody is offline
AF -Advisor
Re: 318 in a Dart?
Due to the bore/stroke ratio (relatively small bore), 318 is not really a good candidate for performance mods. We've seen a few that were good runners, but for the most part, they're better as "torque" engines (lower engine speeds). I agree, one TOUGH engine!
The aforementioned 340 is probably the best of the MOPAR small blocks. For a street engine, in a reasonable price range, we recommend the 360. They are MUCH more available than 340, and make a ton of torque. Torque is the primary performance measurement for a street car. Lightly modified, they can easily make 350-400 horsepower, as well. And on 93 octane.
Old 05-17-2005, 01:29 AM
Fleet 472's Avatar
Fleet 472 Fleet 472 is offline
These specs should be of some help:
('69 Dart, Road Test magazine, Aug., 1969)
Engine/hp................. 318/230
Rear axle ratio........... 2.76:1
Curb weight.............. 3,100 lbs.
0-30 mph................. 2.5 secs
0-40 mph................. 4.7
0-50 mph................. 6.5
0-60 mph................. 9.8
1/4 mile................... 16.54 secs @ 84.80 mph
('72 Dart, Road Test, May, 1972)
Engine/hp................ 318/150 (net)
Rear axle ratio.......... 2.76:1? (not mentioned)
Curb weight............. 3,000 lbs.
0-30 mph................ 3.0 secs.
0-45 mph................ 5.2
0-60 mph................ 8.2
0-75 mph................ 13.2
1/4 mile.................. 17.4 secs @ 85 mph
Fuel mileage............ 14-18 mpg
('73 Dart Sport, Road Test, Sept., 1973)
Engine/hp............... 318/150 (net)
Rear axle ratio......... 3.23:1
Curb weight............ 3,400 lbs.
0-30 mph............... 3.6 secs.
0-45 mph............... 6.0
0-60 mph............... 11.0
0-75 mph............... 17.4
1/4 mile................. 17.9 secs @ 76.46 mph.
Fuel mileage........... 12.2-15.5 mpg
'66 Plymouth Fury VIP (383), '69 Cadillac Fleetwood Brougham, '70 Sedan de Ville, '76 Fleetwood Seventy-Five Limousine
Old 06-28-2005, 08:56 PM
sub006 sub006 is offline
Re: 318 in a Dart?
Unless you're seeking ultimate gas mileage, I recommend a 340 or 360. Great, better-breathing, heavy-duty equipped engines!
Old 09-22-2005, 07:40 PM
Sublime69 Sublime69 is offline
I like the 318.. I have a 69 Dart and i put a 318 in it that came out of a 74 scamp i had.
I put the smallest cam that com cams make for a small block mopar, a edelbroch performer dual plan intake and a junk holly 600 vacume secondary. it also had $99 headman headers, 2 1/4" exhaust and dynomax ultra flow mufflers(no tail pipes)
Old 09-22-2005, 08:03 PM
PeteRR PeteRR is offline
Re: 318 in a Dart?
Go to Hot Rod's website. They have a recipe for a 400 horse 318 there.
Pete.
1968 Plymouth Road Runner
451 Stroker + Keisler 5-Speed OD manual trans
Old 09-22-2005, 08:14 PM
Re: 318 in a Dart?
Yep, thats a good article..
http://carcraft.com/howto/116_0401_318/
Old 09-22-2005, 08:20 PM
Re: Re: 318 in a Dart?
Nice Dart. What are you using for power? Stroker sb?
Pete.
Old 09-22-2005, 08:28 PM
Re: 318 in a Dart?
Its just a 318 on spray.. but its getting a procharger in a couple months.. just a crusier
how about you, hows that strocker workin out for ya?
