Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-19-2005, 07:27 AM
Twin1 Twin1 is offline
Brake lock up
Brake problem solved. I posted several weeks ago,that my left front brakes where not releasing when letting off the brake pedal,and causing my brakes to heat up. So after bleeding all 4 corners and changing the caliper that didn't work.I got a reply from another member to change the brake line to that specific wheel and man that solved it. I could haved saved time and money. I will always post my questions on the forum before I become Inspector Gadget . Thanks fellow forum members.
Old 02-19-2005, 07:51 AM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
Re: Brake lock up
thanks for the input. I'm sure this info, as well as other info posted by other members, will help someone in the future
Old 02-20-2005, 03:08 AM
2000CAYukon 2000CAYukon is offline
Re: Brake lock up
I am glad that my post helped you.
I had learned the hard way as young mechanic in a tire shop. I put two new calipers on a motor home before I called one of the other shops. It was a good learning experience.
This forum allows us to learn for other's experiences as well as help others with the ones we have experienced.
//2000CAYukon
