Old 02-19-2005, 02:18 AM
hunter01 hunter01 is offline
excessive idling time cause engine wear ?
I've heard that letting your engine idle for long periods of time can cause damage due to low oil pressure. Is this true?
If this is true, can damage be minimized by increasing or varying rpm's ?
I ask because I've installed a high amperage (250amp) delco alternator in order to be able to recharge an auxillary battery (115 a/h delco voyager) at idle. I haven't hardwired anything yet so I'll be using jumper cables and an ammeter to test the recharging rate.
I'm thinking of adding some kind of mechanical throttle kicker to raise the rpm's to speed up the process. Or, should I use a scan tool to increase rpm's? I seem to remember a test function of the scan tool that raised engine rpm's to 1000.
Would this be harmful to do for 1 hour?
Any thoughts on this will be greatly appreciated.
2002 S-10 Blazer 4X4
4.3L vin W
Old 02-19-2005, 10:14 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: excessive idling time cause engine wear ?
Naw, you will be fine, don't raise the rpms.
The engine will do it itself if the charging rate gets to low.
Where did you get a 250amp delco alternator?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-19-2005, 10:49 AM
This is where I got the alternator from.
http://www.alternatorparts.com/Extre...144%20type.htm
Old 02-19-2005, 12:06 PM
BlazerLT's Avatar
AF -Advisor
How long will you be idling it?
All day long?
Old 02-19-2005, 12:20 PM
Just long enough to recharge the battery. My inverter shuts off when the battery voltage drops to 10 volts. I have to do some testing to see how long it takes to recharge from 10 volts to a full charge. Maybe 1 hour a day?
Old 02-19-2005, 12:29 PM
BlazerLT's Avatar
AF -Advisor
Your alternator is not a battery chanrger.
Remove it and charge it with a battery charger only.
Old 02-19-2005, 12:52 PM
blazee's Avatar
blazee blazee is offline
Problem?
I have heard idling for long periods of time is bad, too. I'm not sure all the reasons why. It isn't due to low oil pressure though. The mininum required oil pressure for a 4.3 at 1000rpm is 6psi (yep that's it). Most of them have between 30 and 40 at idle so...oil pressure is not an issue.
Old 02-19-2005, 12:59 PM
blazee's Avatar
Problem?
Re: Re: excessive idling time cause engine wear ?
Are you planning on doing this every day? You better make sure it is a good deep cycle battery.
BlazerLT is right an alternator is not a battery charger, it is a battery maintainer. Repeatedly using it to charge a dead battery will kill it.
Old 02-19-2005, 02:22 PM
I'm not going to do this every day maybe a couple of weeks out of the year when I'm on vacation. The battery is a delco voyager M30HMF 115 amp-hour. How low should I let the charge go?
Old 02-19-2005, 02:29 PM
BlazerLT's Avatar
AF -Advisor
Is it a deep cycle?
Old 02-19-2005, 02:40 PM
blazee's Avatar
Problem?
Is that one of those with the blue sticker and a little green, red, or black charge indicator window?
I know I've owned one of those for one of my boats, but I'm not sure which one it was. (I've owned a lot of trolling motor batteries) If it is the one I am thinking of...thay are pretty good batteries and hold up well.
Old 02-19-2005, 11:24 PM
Yes I'ts a deep cycle. Also, they don't put those green dot's on them anymore it causes more problems than it is worth.
As for an alternator not being used to recharge a battery, what about on a boat? I've seen a lot of dual battery systems where the auxillary battery is recharged by the alternator. (I know, wrong forum.
Old 02-20-2005, 12:26 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
then use a mariene alt in your vehical
Old 02-20-2005, 02:58 AM
What makes a marine alternator different?
Old 02-20-2005, 08:22 AM
BlazerLT's Avatar
AF -Advisor
Whta are you going to be powering with the second battery?
Also, in a boat application, there is usually a battery charger incorporated into the boat's electrical system which charges the battery up when you are hooked to 120v AC when you are docked at a powered parking spot.
We never idled the boat to charge ours up. 460 big block doesn't make for an economical battery charger if you catch my drift.
Our boat was a 30 foot Bayliner Avanti and it has one of those HUGE deep cycle batteries.
