Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-18-2005, 10:45 PM
ssenay72 ssenay72 is offline
Tie Rods and steering
Any major tricks to changing out tie rods other than the alignment issue? Or are they pretty much bolt in and out. Also should i change out anything else directly related while im there?
Old 02-19-2005, 10:01 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Tie Rods and steering
bolt in bolt out.
You will have the measure them so you get the new ones in the right way.
Then you should get an alignment done.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-19-2005, 10:09 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Do not forget to grease them... I also reccomending getting a new connecting sleeve as the old one will be a bitch to work with
Old 02-19-2005, 10:16 AM
BlazerLT's Avatar
AF -Advisor
So true, usually rusted badly.
Old 02-24-2005, 07:23 PM
ok riddle me this. i bought new inner and outers and sleeves. put them in measured and all. looked fine. took it for a ride and it felt like the tires were gonna fall off. went back to the garage and took a look. maybe i didnt tighten them enough? maybe waaayyyy out of alignment now. I dunno. Maybe it magnified another problem? Alll you help is greatly appreciated. There is still some side/side movement but its better than what it was. ALSO GET THIS I BOUGHT TRW TIRE RODS, THEY HAVE NO GREASE FITTINGS. EXPLAIN THAT?!? THE GUY SAID THE GOOD ONES USUALLY DONT.
Old 02-24-2005, 07:26 PM
rlith's Avatar
Did you grease them prior to driving? You MUST get an alignment after doing them, I don't care how much you measure..How are your ball joints? Are they greased?
Old 02-24-2005, 07:52 PM
they dont have grease fittings!! believe that?? the lowers were replaced maybe a year ago. they looked somewhat greased. my grease gun is busted.
