Old 02-18-2005, 09:26 PM
flashymike flashymike is offline
Send a message via ICQ to flashymike
Question 1996 S10 4.3L Vortec Lifter Question PLEASE!!
I'm changing the lifters in my 1996 S10, 4.3L vortec. I got the manifold off ok but I'm unsure how to get the piece off that is over the lifters. Its long, looks like it may be made of plastic. There is one over each set of lifters on each side of the motor. It looks like there are two silver things holding it to the block. HOW Do the pieces over the lifters come off? It doesnt look like a nut or anything. What do I need to do to get them off to get the lifters out? THANKS
Old 02-19-2005, 04:31 AM
nxk2000 nxk2000 is offline
looking at some pics when i changed my intake gasket it looks like maybe it just snaps in place. don't know for sure just a quess.
Old 02-19-2005, 06:12 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 1996 S10 4.3L Vortec Lifter Question PLEASE!!
To pull the lifters you will also have to pull the heads...
Old 02-19-2005, 09:49 AM
why do you say that i have to pull the heads as well? the only thing keeping me from getting the lifters out is that plastic piece. the heads dont appear to be in the way. unless im missing something, and the heads have to come off to get the plastic piece offf from ontop the lifters?
Old 02-19-2005, 09:52 AM
rlith's Avatar
I'm thinking of the push rods... doh! Anyway, there should be 3 13mm bolts across that plastic piece, then 2 across the top from what I rmember...
Old 02-19-2005, 10:07 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Why are the lifters being changed anyways?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-19-2005, 11:42 AM
The lifters are being changed because the ones in the motor are collapsed. The truck started making a clicking sound when cold and 3 local mechanics told me it was the lifters. From what I can see they were right. It got so bad that it even caused a rocker arm to break in half.
Old 02-19-2005, 12:09 PM
BlazerLT's Avatar
AF -Advisor
Tell me this, have you ever done a engline flush on it?
Also, what oil filter do you use.
Chances are, it is not the lifters at all.
What oil filter ?
Old 02-19-2005, 04:35 PM
my problem with the plastic pieces over the lifters ended up being two 3/8" bolts.
The lifters were a problem. a couple of them were definetly collapsed missing their discs and retainers, i ended up replacing the lifters and rocker arms. a couple of push rods should have been replaced but i ended up making them work with a file.
Old 02-19-2005, 05:00 PM
BlazerLT's Avatar
AF -Advisor
Where did the missing parts go?
Old 02-19-2005, 06:36 PM
they made their way to the oil pan. i just took the truck for a test drive its running better than ever.
Old 02-19-2005, 06:46 PM
rlith's Avatar
Hope you were able to get them out
Old 02-19-2005, 07:11 PM
BlazerLT's Avatar
AF -Advisor
wow, you are lucky.
Old 02-20-2005, 12:24 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: 1996 S10 4.3L Vortec Lifter Question PLEASE!!
Originally Posted by BlazerLT
wow, you are lucky.
lucky is right, if they wouldnt of made it through, it would have been one heck of a replacement
Old 02-20-2005, 08:24 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 1996 S10 4.3L Vortec Lifter Question PLEASE!!
Yea, a whole new motor.
