Old 02-18-2005, 08:54 PM
westonfire1 westonfire1 is offline
BCM programming?
My 1998 blazer needs a new bcm and and the dealer says there is programming involved with installation. Does anyone have any info to do this on your own ordoes it have to be done at a dealership?
Thanks
Old 02-18-2005, 10:55 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You can do it yourself if you have a Tech 2 Scanner...They only run about 3000.00, otherwise you need the dealer.
Old 02-19-2005, 05:07 AM
ricksza's Avatar
ricksza ricksza is offline
Re: BCM programming?
You not only need the Tech2 scanner, you need the TIS Program (about another $3000 from GM) which has the programing for the vehicle.
If you don't have keyless entry, now's the time to do it. It's part of the programming.
Old 02-19-2005, 05:50 AM
rlith's Avatar
What you should do is grab the bcm or ecm from a wrecking yard... Then have it reflashed, it will save you a good bit of money.
Old 02-19-2005, 01:40 PM
ricksza's Avatar
Make sure it's the exact same part number & not water damaged.
