Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-18-2005, 07:45 PM
njdjh2o njdjh2o is offline
oil pump replacement
Do anybody every change the oil pump on their Bird, if so what is the difficulty rating if it is 1 to 10.
What is the process I need to go though.
Old 02-18-2005, 10:36 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
You will have to remove the front timing chain cover & timing chains.
I'm not sure if you have to remove the oil pan. You probably do.
The oil pump is #33.
Here you can see the oil pump behind the timing chains.
Old 02-19-2005, 10:24 AM
sorry I forgot to meantion it is a 93 v6 lx
Old 02-19-2005, 11:15 AM
97Bird's Avatar
97Bird 97Bird is offline
Re: oil pump replacement
If you're mechanically inclinded a 2-3, if not a 10. If you want to do most of the work on your car then go to helminc.com and spend $80 on the factory service manual and $32 on the electrical and vacuum troubleshooting manual. Best money you will spend on your car for most of your answers.
Old 02-19-2005, 02:09 PM
Re: Re: oil pump replacement
Yes, I am, I just gradutead from a automotive technical school (Lincoln Technical Institute), plus I have over 20 years of working on my own cars. And as you know every car is made different. This is my first Ford I every own and worked on.
