Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-18-2005, 07:36 PM
skitzo247 skitzo247 is offline
318i
I have a 318i that seems to have a fuel or sensor problem. The engine itself sounds strong but it makes sporadic idle changes and runs intermittently as if something was partially clogging the fuel filter and then not... I'm hoping that someone with veteran experience will read this and instantly recognize the telltale signs. I thought that the computer (above in the glove box)may have been faulty so I replaced it but that didn't work. It must be one of the sensors but that will take some time because I have zero experience. Any suggestions would be welcomed and appreciated.
Thanks
Old 02-21-2005, 01:07 PM
Skycity_BMW's Avatar
Skycity_BMW Skycity_BMW is offline
Send a message via Yahoo to Skycity_BMW
Re: 318i
get a fault code reader . .that should help . . . may o2 sensor or coils . . . .
Old 03-27-2005, 09:37 PM
frazier2k1 frazier2k1 is offline
Re: 318i
Thanks
I have a 85 318i also and have the same idle problems. I've been told u have to replace the Idle control brain(in glove box) AND the idle control valve. (right on top of the engine) . both u can do yourself. ( i replaced my own alternator and belts. and I like u HAD ZERO experience. it was pretty easy.. later.. hope that helps
