Old 02-18-2005, 06:57 PM
kurtty kalongi kurtty kalongi is offline
po134 code..
i just ran a diag on my car at autozone cause the check engine light came on, the code means o2 sensor no activity(bank 1 sensor 1)
i was just wondering if anyone could help me with possibilities that could cause this other than a bad o2 sensor
Old 02-18-2005, 07:16 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: po134 code..
(PO134-Upstream HO2S stays at center) I would replace it.
(bank 1 sensor 1 is PO135)
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-18-2005, 08:23 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: po134 code..
make sure that its plugged in and that the wires are ok. if the wiring looks good then you just need to replace the sensor.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-19-2005, 03:31 PM
Re: po134 code..
ok, thanx, the wiring looks good, and i got a friend witha eclipse he is scrapping, so he said i could use his old o2 sensor to test it
Old 02-20-2005, 01:05 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: po134 code..
scraping an eclipse?? NEVER! there should be a law against it or something? what year and model and what's wrong with it, maybe i'll buy it for parts.
95 Talon TSI AWD
97 Eclipse GST
