Old 02-18-2005, 06:57 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
Question Brake Fluid
Stupid Question: How do you add brake fluid to a 1996 Windstar without taking the cowl cover off??? I was thinking of running a small piece of tubing to the reservoir and doing it that way, any other ideas???
Old 02-18-2005, 08:15 PM
martymoose32 martymoose32 is offline
Re: Brake Fluid
I use a turkey baster with a large bulb. Be sure to rinse it thoroughly afterwards.
Old 02-19-2005, 12:00 PM
wiswind wiswind is offline
Re: Brake Fluid
Not a stupid question at all....but an easy solution.....
1st...remove the cap from the bottle and remove the foil seal.
Put the cap back onto the bottle....
Then.
Leave the cap on the bottle.....until....
Place bottle to the passenger side of the master cylinder fill cap....you will have clearance there to manuver the bottle to the pour position.
With the bottle upright.....
REMOVE the cap and pour.
Put cap back onto the bottle....and work your way back out past the trottle cables...and other such obstructions.....
Make sure to use new fluid from a sealed bottle. Once the bottle is opened....the fluid will start to absorb moisture....which is a bad thing.
My point being.... don't use fluid from a bottle that was opened a few years ago....and has been sitting around the garage since then.
Old 02-19-2005, 12:58 PM
12Ounce 12Ounce is offline
Re: Brake Fluid
Shot glass.
Old 02-19-2005, 05:44 PM
Re: Re: Brake Fluid
Thanks for the suggestions. I just used a short piece of tubing to act as a funnel which worked well.
