Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 02-18-2005, 05:33 PM
furbrother furbrother is offline
Cd Player Wont WORK! HELP
SO I changed it out and bought the wire kit for it. Plugged in the cd player and it didnt power on So I said lets see I plugged the old one back in and it didnt power on. So I started to look at the fuses and checked them the best I could, the chart sucks! Any suggestions on what to do next?
Old 02-18-2005, 06:36 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: Cd Player Wont WORK! HELP
hopefully you didnt fry anything when installing the 1st one....
almost that time
my sig made mommies cry, thats why i had to change it..
Old 02-18-2005, 06:38 PM
Re: Re: Cd Player Wont WORK! HELP
What would I have fried?
Old 02-18-2005, 11:06 PM
Tib Guy
Re: Re: Re: Cd Player Wont WORK! HELP
i wouldnt know where to begin, im not too good with wiring/ car electronics
almost that time
Old 02-22-2005, 09:36 PM
tibby01 tibby01 is offline
i dont think you would have fried anything. im betting its a fuse. just take them all out.
Old 02-23-2005, 05:16 PM
free2roamaz free2roamaz is offline
Send a message via AIM to free2roamaz
Well there are many things you could check. First off did you splice any of the wires or did you just use the aftermarket harness? To check fuses, there should be a fuse box with I think 2+ fuses that are stereo related, in the driver side, near the pedals, as well as one in the engine compartmen fuse box. Your boxes should have some sort of diagram or guide on the lid that will tell u which fuse is which. If this u cant find a blown fuse or need more help post, or send me an PM.
Old 02-24-2005, 07:22 PM
Rickna's Avatar
Rickna Rickna is offline
IS-F
If you're sure it's not a fuse, I woud start by checking voltages at the connector. Did you do anything to the ground? If you did any splicing, double check them. I rarely use crimps, I prefeer to solder & heat shrink.
Yellow=12v always hot
Red=12v when the key is switched to Acc.
