Old 02-18-2005, 03:18 PM
cerestialcivic91 cerestialcivic91 is offline
Send a message via AIM to cerestialcivic91 Send a message via MSN to cerestialcivic91
Question Front lower Xmembers
Hey everyone,
i want to look into installing a front lower crossmember for my 91 civic that will have a b18 with 92-95 rad in it in a little bit...
i have heard lots about the Z10 motorsports ones
if all of you can give me your opinions on this and/or there are other better ones out there that would be great.
thanks
Mike
Old 02-18-2005, 03:22 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Front lower Xmembers
there alot out there. L-con, full-race are the 2 i recommend
Team Lonely Drivers
Old 02-19-2005, 07:05 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
www.jimfab.com
he makes an excellent front crossmember, with adjustable radius rods.
not to burst your bubble or anything, but you know that the radiator mounts to the rad support and not the crossmember right? i know that some aftermarket crossmembers have rad mounts on them, but the stock mounts are on the radiator support.
just making sure you know that before you get the 92+ style radiator
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-19-2005, 07:34 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
so your saying on the z10 system to not get the rad. mount support?...curious cause i was looking into getting z10 setup...and gonna run the smaller radiator
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-19-2005, 10:54 PM
if the z10 is for the eg radiator and your gonna run a eg radiator, then get it
Team Lonely Drivers
Old 02-20-2005, 08:23 AM
EF You's Avatar
EF Life Giver
yeah, all i was saying is that if you plan on running a later style radiator, to keep in mind that the stock radiator mounts arent on the crossmember, and that you would need to either modify your radiator support to hold the new style radiator, or get a crossmember with the mounts on it
