Old 02-18-2005, 01:32 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Which would be better?
To have the transmission shop do my rear end swap (estimated 5-600 dollars), or have it delivered to the shop, pick it up with a truck (i can use a friends since it'll be local - but actually john let me know which vehicle youre bringing when you come up this way), and have a few people off of NJFBOA who know what they're doing come over and we do the swap at my house (10 bucks for gear oil, 5 bucks for lim slip additive, however much to feed them)
Input? Suggestions?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-18-2005, 01:40 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Which would be better?
I would say it would be better to have the shop do it cause they are Pros, but it would definately be worth it to do it the other way, it's way cheaper plus if those guys know what they are doing, they wouldn't have a problem and it would be just as good as shop work.
Old 02-18-2005, 02:27 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
I always get a sense of pride in doing my own work or at least helping out any way i can.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 02-18-2005, 02:52 PM
Xbox2202 Xbox2202 is offline
Send a message via ICQ to Xbox2202
I try to do just about everything I can to my car myself, but it's mostly because I'm cheap. I have pride in doing something like that myself, but it would probably be easier to have it done professionally, and if they screw it up, you can get them to fix it.
1994 Camaro V6 A4 - RIP 3/1/06
http://www.cardomain.com/memberpage/805164
1994 Camaro Z28 A4 - Bought 4/6/06
Old 02-18-2005, 03:43 PM
WeirdRich WeirdRich is offline
Send a message via AIM to WeirdRich Send a message via MSN to WeirdRich Send a message via Yahoo to WeirdRich
So eather...
$600
or
approx. $50 and the opportunity to maybe learn how to do it yourself the next time...
Id go with the latter.
I do all my own work even if I dont know what Im doing. If I didn't, it would just sit. I barely have the money for parts let alone labor. Plus, if you don't try then you won't learn.
1994 Camaro Z28 Convertible 385
1981 Honda CB 750 Custom
Old 02-18-2005, 04:19 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Re: Re: Which would be better?
I agree it would be more satisfying to do ur own work. If u have never done it make sure they know what they are doing.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 02-18-2005, 04:54 PM
Dober89 Dober89 is offline
Are you swapping the whole rear end or just changing gears?? If your changing gears I would let the shop do it because its a real pain in the ass to setup properly.
Old 02-18-2005, 05:17 PM
Well John did the gear swap... but probably cuz of shit that the car's been thru in the past the rear is a little fucked up, and... that got worse.
So now it's a whole rear
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 02-18-2005, 05:25 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Input? Suggestions?
Why do you need to know which vehicle I am bringing?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-18-2005, 05:36 PM
FormulaLT1's Avatar
Fight the powwa!!!
What happen was that I went up to Kasey house to help with the gear install and we ran into a couple of snags along the way. Apperently there was a metalic rubbing sound coming from the rear prior to me getting there and we had a snag with one of his drums coming off when we first attempted to do it. Then after the second time apperently a open V6 differential don't need the use of a spacer when using 2 and 3 series gears but once we had the rear end opened we noticed that the passenger side bolts of his rear were bowed and the thread to the bearing cap damage as well at the bearing chewed up alittle do to him hitting a curb with the rear tire on that side. So long story short the bolt wouldn't go back in straight and I didn't have a tap or die kit(Kasey and father later fixed the threads with a tap&die and finished the job) with me and the other side went on fine. So I set preload checked backlash while holding the opposite cap in place and checked contact pattern. Which were all fine. The rear didn't make any noise and worked fine til he went to get his exhaust done. When he got it back there was a noise coming from back there and after a mechanic opened up the rear he saw that a tooth on the gears was chipped and I am now wondering if since the bolts and threads were damaged if that axle on that side isn't bowed as well. Anyway thats what happen. Kasey correct me on anything if I am wrong.
Old 02-18-2005, 05:54 PM
That's it pretty much... was wondering what vehicle because first off wondering if you wanted to help out with this, and if so and you have your truck then possibly if we could use it to get the rear from the shop. I can use a friends tho
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 02-18-2005, 06:28 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'll let you know if I can get the truck.
Old 02-18-2005, 07:41 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Sounds like your rear end has taken quite a pounding
Also, are you going to feel comfortable having a bunch of people's hands on your rear end?
Old 02-18-2005, 11:53 PM
somebody had to say it, lol
Old 02-19-2005, 05:40 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
i payed 500 for my rear end swap learning is fun but thats for sukka's....lol just kidding. i try an do alot of my own work also but big jobs i pay the pro's just to ensure when im doing 80-100 my damn car wont fall apart because i forgot one damn screw or had a few extra parts left when i was done.(i know im not the only ghetto ass in here) it happens sometimes and sometimes i dont wanna take the chance. pay someone if u dont feel like risking it, and if u can afford it then do that shit for real, why get dirty if u dont have 2.
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
