Old 02-18-2005, 12:43 PM
DRGREENTHUMB1001 DRGREENTHUMB1001 is offline
where to find replacement parts
Anybody have any suggestions for a website or a catalog wholesaler for Blazer parts. My 98' has sprung in oil leak in the oil coolant line that runs from the filter to the radiator. Napa had the replacement for the 2wd but not for 4wd's. Plus, you know Auto Zone wont carry a part like that, and I would like to avoid being raped by a Chevy dealer. Thanks
Old 02-18-2005, 02:09 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: where to find replacement parts
try http://www.gmpartsdirect.com. They sell GM/ACDelco parts.
You'll need to know the exact part number, as it's rather hard to return parts (they're an internet contact only parts supplier, Flow Chevrolet in N.C.) They do have a GM parts catalog to search for the part numbers.
They sell at wholesale prices but tack on a good charge for SH.
An example; I bought a fuel level sensor from them for $72 including SH.
The cheapest I could find it anywhere else on the web was $85 not including SH. The part lists for $120. (My local chevy dealer only sells parts at list price)
It took 1 week to get the part from the time I placed the order.
Old 02-18-2005, 06:26 PM
blazee's Avatar
blazee blazee is offline
Problem?
http://www.rockauto.com
This from one of my other posts:
Mine was bad where the line goes into the bottom of the radiator. Believe it or not, the hard plastic wire loom rubbed through the metal line. I suggest everyone check theirs to make sure they won't have the same issue.
Filter to radiator.....$20
Filter to engine..$33.79
2wd:
Radiator to engine..$28.79
they are cheaper at Rockauto, because the quality is nothing like the originals (didn't really expect it to be). The only issue I saw that might be a problem (other than the lines being thinner than original) is that the end that goes to the top of the radiator has a bend instead of a 90 degree connector. The extra distance that it sticks out with the bend makes it rest right up against the air box, this could allow it to rub a hole in the line. I put a short piece of hose over it for protection.
Old 02-18-2005, 07:27 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
www.lmctruck.com
you can order yourself a catalog that will have everypart you can imagine in it and plus its free..
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 04-07-2005, 02:22 PM
thanks for the info guys
Old 04-07-2005, 02:48 PM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Re: Re: where to find replacement parts
Originally Posted by s10blazerman4x4
www.lmctruck.com
...except no blazer parts after 1991.....bummer
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
