Old 02-18-2005, 11:17 AM
dhcoon dhcoon is offline
97 Blazer dies
My 97 Blazer would die briefly when driving down the highway. Sometimes it would re-start on its own (and sometimes not). No fault codes.
I noticed that some of these outages were accompanied by a change in dash lights and I observed the Airbag light flashing for a couple of seconds after the outage - similar to what happens immediately after you turn the ignition key on.
I also noticed that sometimes when I went to start the car, after I turned the key on (but before I started cranking), there would be a couple second delay before the dash lights would turn on (coincident with the sound of a relay click).
After searching the forum, I saw that several people had luck changing the ignition switch or cleaning the contacts on the ignition harness for similar symptoms.
I bought the ignition switch (comes with wire harness) at Autozone for $90 and my brother helped me put it in. It took about 2.5 hours (mostly because of the small reverse torx screws on the ignition switch that we didn't have a socket for). We ended up using needle nose vise grips, but access to the upper screw is not good so it took some fiddling with. Buy a 3 mm socket before you start the job.
Bottom line is - it's been a week and there have been no more issues - so I'm pretty sure it's fixed. I didn't see anything on the connector end of the harness that would indicate that cleaning the contacts would do any good - so I think the problem is internal to the switch itself.
I thought I would post this in case anyone else is having this type of problem - pay attention to the symptoms on the dash, and if they are similar, it's probably your ignition switch.
I had called my trusted mechanic and he wanted to start with the simple stuff - tune up, cap, rotor, etc. which would have probably cost me $200 without fixing the problem. (it's like he wasn't even listining when I described the symptom!).
Good luck - DC
Old 02-18-2005, 11:22 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Blazer dies
Ah, yet another happy 1997 ignition switch fix.
Glad to see it helped.
But also, you should do a tuneup anyways if it has never been done.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-18-2005, 06:08 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 97 Blazer dies
Good job!
I would look for a new mechanic, sounds like he is one of those people who think similar problems always have the same solution. A good mechanic will look for the problem before starting to throw parts at it. He will end up costing you a lot of money on unneccessary repairs one day.
Old 03-04-2005, 10:06 AM
gogrannygogo gogrannygogo is offline
Re: 97 Blazer dies
Good luck - DC
I just wanted to thank you for posting this!!! My '97 did this to me last night on the interstate and scared the bejesus out of me. Now I can take it to my mechanic and actually know what the problem is!
