Old 02-18-2005, 11:59 AM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Big Brake Kit?
I'm getting tired of replacing my brakes as much as I do so I'm considering upgrading my brake system. Does anyone have any expierence with after-market brake systems? Any good sites I can check out? Thanks....
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 02-18-2005, 02:10 PM
kingpinn's Avatar
kingpinn kingpinn is offline
Re: Big Brake Kit?
andysautosport.com i think sells them
Old 02-18-2005, 10:09 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Big Brake Kit?
i dont think there is any big brake kits out there for our cars...i know they need to make some...hehe...but i heard alot of peeps just upgrade the brake booster and stuff i dont really know was looking into the braking next jsut finally finished up all my suspenion and got my new rota slipstreams...now aobut to go get some power slot rotors soon go behind these nice rims
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-18-2005, 10:32 PM
Scott82 Scott82 is offline
Re: Big Brake Kit?
You might look into mods done by people who race road courses with Civic's and Crx's
Old 02-18-2005, 11:15 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: Big Brake Kit?
just use front brake system from a 90 93 teg its the same mounting but 9 in rotors. Have to use 15" or bigger rims after the swap.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 02-18-2005, 11:51 PM
Re: Big Brake Kit?
Would Cross drilled rotors make a difference in brake wear?
Old 02-19-2005, 12:09 AM
Cjz89civic's Avatar
AF Premium User
Re: Big Brake Kit?
yes they will make you wear your brakes FASTER.
Old 02-19-2005, 12:23 AM
Cjz89civic's Avatar
AF Premium User
Re: Big Brake Kit?
Also your problem could also be your master cylinder could be bad or the proportioning valve could also be bad. This can cause your rear brakes not to work right or not at all.
Old 02-19-2005, 12:27 AM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
Re: Re: Big Brake Kit?
can you use the rear brakes from the teg for 4 wheel disc swap?
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 02-19-2005, 12:28 AM
Re: Big Brake Kit?
How is that? there is less contact with the rotor. Or does it just peel of the brake layers? "CrossDrilledRotors"
Old 02-19-2005, 01:25 AM
Cjz89civic's Avatar
AF Premium User
Re: Re: Re: Big Brake Kit?
It really depends on what kind you get. Some will wear more because of the holes in the drilling. and most will warp causing you to wear pads faster and have a awful ride. Over all just use Blanks unless you are really RACING in some aspect (road course not drag)
Yes you can. But you need to make sure you use new bushings in the rear for the year of the car you pull the brakes from. Also make sure you get a rear sway bar. Have had a buddy that did this swap and the alinment was wrong (wore tires bad) until the bushings and sway where added.
Old 02-19-2005, 03:37 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Re: Big Brake Kit?
fastbrakes.com makes a nice big brake kit for our cars.....so does Brembo, But be prepared to fork out atleast $700
89 DX: LS Powered
88 CX: Project ZC
Old 02-19-2005, 07:47 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Big Brake Kit?
im using a DA integra rear trailing arm setup with the stock ED civic control arms, and it works fine. im also running DA integra front knuckles on stock ED control arms, and havent had any issues with alignment other than getting better caster measurements. i also used energy suspension bushings everywhere including the large trailing arm bushings. so far the brakes are stock DA integra with SS brake lines, DA integra master cylinder and power booster, as well as DA integra proportioning valve
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-20-2005, 12:15 PM
emil13si's Avatar
emil13si emil13si is offline
I must say that I hate honda brakes eve that I have TAROX G88 with EBC green stuff pads I keep tearing that shit (the discs are so fucked up after a month that when I brake my stearing wheel is going crazy -shaking), those discs are good for a month and then I must do some work on them (to get them in original shape) and again good for one month...but now we found a solution...if I'll have enough money I'll put on 4pot Porsche caliper + big disc, redo that and put on my car...We'll see in a month or two...but till then this discs will go under machinary on monthlly period
CYA
Powered by
CivicTypeKoshiR
Old 02-23-2005, 10:52 AM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
Re: Big Brake Kit?
go with cjz89civic said i got a 4th gen 4door with 90 93 rotors on the front but yeah you have to get bigger rims or if ur riding stock wheels just use integra wheels...
