Old 02-18-2005, 01:23 AM
Christlike Christlike is offline
Question Oil in air filter + oil on bottom of car
I just noticed a problem with my 1991 Ford Escort LX. I noticed that oil has some how been getting into the air filter and casing. I only know that the oil is coming through a hose that goes into area where I add my oil. Basically it looks as though oil is being sprayed into the air filter casing and filter. I do not know too much about cars, but would appreciate any help out there.
In addition, I have noticed that the bottom of my oil pan and surrounding area to that are all coated with oil. Definitely an oil leak somewhere. Any suggestions?
Thank you for replying.
Old 02-18-2005, 09:07 AM
A. Souphound A. Souphound is offline
Re: Oil in air filter + oil on bottom of car
What size engine?
Is the air filter in a metal housing?
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 02-18-2005, 12:00 PM
getdanwilkinson getdanwilkinson is offline
its blowby it means your engine is going . i had the same thing happen in a 88 escort .i tryid to fix it ,but it was like a quart of oil a day in the air cleaner at the end .and then it blew up! have a machanich look at it is all i can say
Old 02-21-2005, 12:59 PM
Steindawg94 Steindawg94 is offline
The oil in your airbox is coming from the breather tube.
