Old 03-19-2002, 05:42 PM
Devedander Devedander is offline
Wiring up surrounds
I just realized how much hassle it's going to be to wire up the surrounds in my car from the amp in the back. Every shop I talk to says they will just wire from the trunk to the console and then splice into the stock wiring into the doors. That seems to kind of defeat the point of the larger wiring I bought. Has anyone tried to get 15 guage wire into their door speakers? How hard was it? Any hints? Thanks!
Old 03-19-2002, 10:57 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i did the same thing the shop did, i just ran the wires to the deck leads and spliced, much easier that way. but if you want it to your doors, you'll need to locate the wire loom leading to the door and open it up, remove the old speaker, making sure you remove the right one, not like the power window or lock wires or anything else, then re-run the new thicker guage through to your new comps. HTH.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-20-2002, 02:14 AM
That's exactly what I was gonna do but it just looks like such a b*tch! I mean the new wire probably isn't gonna fit too nice in with all the old wires (since it is about as wide as the whole wire bundle now) and I figure you have to tie it to the end of the old speaker wire and pull it through, so I figure tie a string to the old wire, pull that through (pretty easy) and tie the string off in a loop so you can't lose a loose end in the door somewhere (that would be absolute hell) and try like hell to get the new wire through. Just wondering if there is an easier way and will it really make a difference? It looks like it should to me but maybe that tiny wire can carry the entire ~150 watts of power to each speaker?
Old 03-20-2002, 02:25 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
the bigger wire won't make that much of a difference, IMO you're just wasting your time and energy.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 03-20-2002, 11:00 AM
crxlvr's Avatar
yea the thicker guage wire isnt really gonna do any good for you anyway, its not worth it for the time involved in the procedure.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-20-2002, 12:33 PM
Ok, well then screw the idea of wiring the doors (the rears are still gonna get big wire cuz they are right next to the amp) should I even wire big wire to the console? Should I just buy some small wire and wire that, it would pobably be less of a lump under the carpet.
Old 03-20-2002, 10:37 PM
crxlvr's Avatar
the thickest you would need to run to the deck would be 10guage, run the wire down the door sills, so you dont see any hump in the floor.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
crxlvr's Avatar
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-21-2002, 01:47 AM
I am installing 15 awg is that a fair size? BTW whats the stock wiring? I know it looks tiny.
Old 03-21-2002, 12:36 PM
crxlvr's Avatar
15 gauge should be more than efficient, i believe stock wire guage is either 20-24guage.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-22-2002, 12:04 PM
It's weird, I was looking into it some more and on the drivers side door there is a cable wrap (the black round kind with a split in it) and in that is some fairly reasonable looking wire (clear insulation, looks bout 1/8th inch) , but when you get in the door and look at where it goes to the speakers the wire is a white insulation and only about half as big looking. What's more the passenger side does not have this wire and wrap going to it (there is a plug to pull out and do it if I want to thoguh). Is this standard? Does this mean the HU goes to the drivers door through that and then back through the dash to the passenger? It's all so complicated.
Old 03-23-2002, 12:02 PM
crxlvr's Avatar
both sides should have there own seperate lines for the speakers, there should be a line to both.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
1985 k10 headunit wiring redka88 C/K 0 04-22-2009 08:53 PM
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 07:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
wiring short in sterring colum? danielgast46 F Series 5 03-23-2009 07:35 PM
transmission wiring help please danielgast46 F Series 0 02-28-2009 09:33 AM
