Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 02-17-2005, 09:51 PM
CivicHonda CivicHonda is offline
Headlights turning yellow
My 98 durango's front lights are turning yellow. What can I do to remove the yellow?
Old 06-12-2005, 01:28 PM
5speede 5speede is offline
Send a message via Yahoo to 5speede
Re: Headlights turning yellow
Actually there's little to nothing you can do about this problem. This is normal wear and tear for clear haed lamps made of this plastic material. Chances are you'll have to buy new covers. Good luck. J
Old 06-13-2005, 08:10 AM
gbic1 gbic1 is offline
I was told by a good friend to wet sand them with 2000 sand paper and then buff them with compond. The yellow is caused by small scratches.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 06-13-2005, 01:59 PM
tommychau tommychau is offline
Send a message via Yahoo to tommychau
98's uses plasic lens housing? Luckily my 2000 model is glass and not plastic.
Old 06-25-2005, 12:35 PM
gapboi210 gapboi210 is offline
Actually there is something you can do about it! Go buy Brasso brass polish. Use this to polish them about 3 times. Depending on how bad yours are it may make them perfectly clear again. Doing this will definitly help remove the yellow oxidation. Other brass polishes work too but I find this one to be the best. Works on tailights too if they are looking coudy and faded.
Old 06-26-2005, 07:46 PM
Campe Campe is offline
I was told that you can buy the glass/plastic cleaner in a car store that is used for convertible back windows. Don't know if it works but it is a cheap try and was told it does.
Old 06-26-2005, 10:41 PM
I know 3M makes a plastic polish and it works well with a buffer. It is expensive and I think the brass polish works just as well.
