Old 02-17-2005, 09:36 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Driveshaft
I am looking to replace my driveshaft with a lightweight one but I dont know which one to get.
GM 1LE Aluminum - the 1LE driveshaft is 2.75" in diameter, Cost $212. It weighs 10 lbs.
RKSport Aluminum - this driveshaft is 3" in diameter and features an internal vibration dampening system. This driveshaft is IHRA legal for Competition Eliminator and Pro Stock classes. $360 from RKSport. Weight is 10 lbs.
Would both of these bolt to all the sock stuff even though they are diffrent sizes (anybody know the stock driveshaft diameter)? These would still have to be strong despite their weight right?
White 07 STI, Bone stock for now
Old 02-17-2005, 09:39 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Driveshaft
i'm thinking about getting a new one myself... mines out of ballance..... i would probably lean towards the rksport one...
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-17-2005, 09:44 PM
ViperJ's Avatar
Re: Driveshaft
Would that bolt right up? Money is a little low and I don't want to have to have a shop install it.
Old 02-17-2005, 09:47 PM
carlos80 carlos80 is offline
Re: Driveshaft
why would you put a driveshaft in,is yours out of balance or damaged in any way?
Old 02-17-2005, 09:58 PM
ViperJ's Avatar
Re: Driveshaft
The stock drive shaft weights around 25lbs, these are 10lbs... That would help acceleration alot wouldn't it (less weight= less power need to get it moving)?
Old 02-17-2005, 10:08 PM
Re: Driveshaft
typically 100lbs of weight reduction will knock off a tenth of a second in quarter mile run, so i don't see how knocking off 15 pounds could help. i'd go with other mods
Old 02-17-2005, 10:20 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Driveshaft
Thestock drive shaft in most of the sixers is a two-piece steel driveshaft. Although it may not be the best mod to do it is definately worth it. If cash is tight I would say go with the cheaper aluminum one with the amount of power the 3.4L produces you have no need for the other one. I was looking into getting a new one a while back too, just to get rid of the two piece crap and a little weight. (Mostly the former)
Old 02-17-2005, 11:02 PM
Dober89 Dober89 is offline
Re: Driveshaft
Any driveshaft from an fbody from 1984 onward will fit as long as its from a 4 spd auto, or 5/6 spd manual transmission. I put the 1LE in my 89. It doesnt have as large of a diameter as the newer LS1 driveshaft but it has a thicker wall and is a little stronger. On hard launches the LS1 shaft will go before the 1LE one will.
I didnt even know rk sport offered a driveshaft. I would go with dennys though personally. The 1LE should be fine for you though unless your planning on beating on it with lots of power and hard launches.
Old 02-17-2005, 11:20 PM
ViperJ's Avatar
Re: Re: Driveshaft
I realize its not going to save much weight that way. Think of a lightned flywheel less weight=quicker revs, it will help in acceleration.
Thats what I was think also. Eventually I want to have my car running low 14's high 13's but thats going to take a while.
Old 02-17-2005, 11:31 PM
ViperJ's Avatar
Re: Driveshaft
Most V6 F-Bodies come with a two-piece driveshaft from the factory (although some 99+ models come with a one-piece steel unit). Two-piece units were installed from the factory because they reduce vibration and noise better than a single-piece unit, but if you are pushing any serious amount of torque you run a risk of snapping the driveshaft in half. As an upgrade you can go with a one-piece driveshaft made either of steel, aluminum, or carbon fiber. The stock two piece driveshaft weighs around 22 lbs while aluminum units weigh in the neighborhood of 10-12 lbs. Carbon fiber driveshafts are even lighter (typically 5-7 lbs) but are much more expensive.
Just to give out some info
Old 02-17-2005, 11:52 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Re: Driveshaft
Less rotating mass
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-18-2005, 01:16 PM
Re: Driveshaft
Are the Drive shafts the same for the automatics and the manuals?
Old 02-18-2005, 04:56 PM
Re: Driveshaft
Yea the driveshafts are the same for manuals and automatics so you can get one from any newer fbody.
13-14s times would be a breeze for the aluminum driveshaft.
Old 02-18-2005, 07:53 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Driveshaft
how about 11-12s?
