Old 02-17-2005, 08:04 PM
1534dover 1534dover is offline
Can the air conditioning compressor leak?
I've found some light oil, about like three in one oil, about two feet in from the outside of the right front tire on my 92 park avenue. It appears that the air conditioner compressor is right above it. Can the compressor leak oil? It is fixable without replacing it? What would be the approximate cost? I had it converted to R134A about 18 months ago.
Old 02-18-2005, 01:00 AM
yogi_123rd yogi_123rd is offline
Re: Can the air conditioning compressor leak?
The AC system does use a light oil in the system. It lubricates the inside moving parts of the compressor. Dept/part stores sell both cans of R134 seperately or a recharge kit consisting of a can of oil mixed with R134. Simply add oil/R134 as you normally would to charge the system.
Old 02-18-2005, 04:42 AM
auto trainy auto trainy is offline
First look at all ac connections(hose fittings ect.) even a damp looking connector could be a leek under pressure.If the oil is dripping out it may not be ac oil.
Old 02-18-2005, 05:41 AM
volkerc's Avatar
volkerc volkerc is offline
if the compressor leaks out oil your ac would not work/blow cold anymore because it would ultimately leak out the freon. chances are if the oil is gone it would also seize up. those compressors have a seal at the shaft that wears out.
back to the oil, what color is the oil? does it have the appearance of brake fluid, is it colored in any way?
