Old 02-17-2005, 07:48 PM
rallyway rallyway is offline
will ZC tranny bolt on D16A6 with no modifications?
i was wondering if anyone could help me out. will a ZC tranny bolt directly into my 90 Civic EX (D16A6)? will the stock axles and everything work? if not, what is needed for this tranny to fit? thanks.
Old 02-17-2005, 07:56 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
90-93 teg axles plus the zc intermediate shaft that should come with the tranny. but yes, it will bolt up to your engine.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-17-2005, 10:44 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: will ZC tranny bolt on D16A6 with no modifications?
i have the same car, why you wanna bolt up the ZC transmission?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-18-2005, 11:24 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Re: will ZC tranny bolt on D16A6 with no modifications?
better gear ratio for accelleration.
u can even combine the A6 tranny and the ZC tranny, and get one hell of an acceleration upgrade.
Old 02-18-2005, 11:37 AM
icE_x's Avatar
wow that's interestin...but not too sure an auto zc tranny would swap too well, i'll ask around
when i go to do my tranny/engine swap and upgrade (swapping in a built d16a6 for boost down the road) i'll see if maybe i can get the zc auto tranny upgraded instead of the a6 auto tranny
Old 02-18-2005, 12:57 PM
thanks for your help. my stock tranny has the typical bearing noise at only 100k miles! so i found a deal on a ZC tranny for $150 but i guess i am going to have to come up with some teg axles. thanks again.
Old 02-18-2005, 04:52 PM
icE_x's Avatar
yeah my tranny "clicks" into gear sometimes with a clunk, so i'll be investing in a replacement sooner than i think
Old 02-18-2005, 05:30 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
I was told by an aftermarket axle company (can't remember which one) that the 86-89 teg axles are the proper axles for the zc swap....
But, i'm sure you're right seeing as how you have a ZC...
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-18-2005, 06:25 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
They are 90-93 you just need to remove the dust seal at the hub for them to work
My Name is Roberto AKA. Berto
Old 02-19-2005, 08:30 AM
what is up with Honda tranny's getting that bearing noise? i have owned at least 5 that have had that problem. i bought a couple of them thinking it was the throwout bearing but after replacing that it didnt aliviate the problem at all. but i have a 97 civic that has 206k and the tranny is fine????
Old 02-19-2005, 11:13 AM
bambam89lx's Avatar
AF - Advisor
the throwout bearing/thrust bearing isn't what makes that noise...
It's the pilot bearing in the center of the flywheel that's making that noise. It has to be pressed out and the new one installed.
